Gilmer Belt Drive on V8
40 replies to this topic
#26 _82911_
_82911_
Posted 19 December 2007 - 01:32 PM
That is not underdriven...
Look at the pulleys. Both crank and waterpump are the same size.= 1:1
Diecrest Eng made the drysump mandrel and hub for my race car. FAULTLESS....
Buy DIECREST.
The other mob sells junk.
Both of the other mobs.
Cheers Greg..
#27 myss427
myss427
  • 1,636 posts
Posted 19 December 2007 - 01:37 PM
I had one on mine a while ago, and belt slap gave me the shits. You would hear like bearing chater noises from it, and it made you nervous about the health of your motor. If you tighten them too much they tear your water pump bearings out! I have put deep groove pulleys on now, I just put up with squeel!
Edited by myss427, 19 December 2007 - 01:38 PM.
#28 _82911_
_82911_
Posted 19 December 2007 - 01:43 PM
5PK serpentine is the answer you are searching for.
Cheers Greg..
#29 MRLXSS
  • 12,419 posts
Buy DIECREST.
Cheers Greg..
^^ Isnt a standard water pump pulley smaller than a Crank pulley? I would assume that my Water pump spins faster than my crank? ^^
If that is the case, then if they are 1:1 then the waterpump is oversized (Which would make it spin less than standard)
Edited by MRLXSS, 19 December 2007 - 01:43 PM.
#30 _raceme_
_raceme_
Posted 19 December 2007 - 02:59 PM
sorry for not being more precise,
i was only ever referring to the crank to alternator ratio.
by the look of both kits, the crank and water pump have the same diameter pulleys which would make them both 1:1, but the die crest crank pulley is smaller than the at racing one, which when you compare it to the alternator pulley would make the alternator underdriven.
I think so anyway... correct me if im wrong.
#31 _LJ355_
_LJ355_
Posted 19 December 2007 - 05:09 PM
What is wrong with Sydney Speed ??
Where do we start :fool:
#32 boomfunk
boomfunk
    Forum Trimmer
  • 2,065 posts
Posted 19 December 2007 - 05:14 PM
if your not a customer of theirs then you be fine :D
#33 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 19 December 2007 - 06:37 PM
right, I have just been out and measured the standard v belt pullys on my car and they are approx. as follows:
crank-155mm
water pump-145mm
alternator-70mm
these are measured to the outside of the pulleys
#34 Obey 1
Obey 1
  • 414 posts
Posted 20 December 2007 - 08:41 PM
Anyone else got comments on these 3 sellers on ebay???
#35 makka
makka
  • 3,559 posts
  • Name:Cohen
Posted 20 December 2007 - 08:58 PM
yeah, steer clear from SSS
#36 Obey 1
Obey 1
  • 414 posts
Posted 22 December 2007 - 06:30 AM
It sounds like I am screwed then when it comes to Ebay.
If I should stay clear of (SSS) which is Atracing and Direct eng.parts
and then Diecrest is underdriven there is nothing left to choose from??
Raceme ...you said you just purchased one ..how did it work out ??
Obey 1
#37 _82911_
_82911_
Posted 22 December 2007 - 07:47 AM
Diecrest is NOT UNDERDRIVEN.....
Re read my post.
Cheers Greg..
#38 _Herne_
_Herne_
Posted 22 December 2007 - 08:25 AM
I am pretty sure mine is Diecrest and I have not experienced any problems whatsoever.
Although Diecrest put their items up for auction on ebay you can always deal direct with them :)
Herne
#39 Obey 1
Obey 1
  • 414 posts
Posted 22 December 2007 - 08:48 AM
Ok Thanks Greg...Also just reading what other forumers are saying about them.But others have said they have diecrest with no probs.
I just rang diecrest as suggested Herne and they sell it over the counter for $150
#40 _greenmachine215_
_greenmachine215_
Posted 25 December 2007 - 04:37 PM
I Bought mine off ebay from AT Racing, Yes i know some of their stuff it shit, BUT I never had shit with my gilmer drive. Sounded awesome, and i only threw the belt once at 7800rpm under load
Heres a clippy of my old motor if anyones interested to hear
GILMER BELT DRIVE CLIP
Cheers :spoton:
#41 _v8slrtorana_
_v8slrtorana_
Posted 25 December 2007 - 07:47 PM
I got one, and have had some problems with it, but not now.
With a crane 286 cam, Ive never had any problems with it, with my old crane 288 cam it unwinds bolts every couple of days. I guess the old cam was savage, and due to the grip of the belt, the poor old 5/15 bolts just could not tolerate it. Yes i used loctite.
It was never over tightened either.
They do look tuff but :D
