Need help with V8 conversion
#1 _LHwannabeV8_
Posted 06 February 2006 - 11:37 AM
I was hoping to drop a 253 or 308 into it within the next year before I get my licence. I was wondering what is a cheap and hassle free option. I am an apprentice so I have the workshop and tools available to help I guess. Can I just drop in HQ running gear in or do I have to get Torana engine mounts to go in? If anyone could help I would be appreciative and grateful. Also if anyone in Victoria (Melbourne/ Hastings area) has any parts that they want to sell that might be helpful as well.
Cheers Anthony
#2 _Yella SLuR_
Posted 06 February 2006 - 02:40 PM
If you running the six, a Holley 500 is way too big (prolly is a 465). Holley 350 should be the goods on a 202.
Posted 06 February 2006 - 03:58 PM
Posted 08 February 2006 - 10:29 AM
#5 _Yella SLuR_
Posted 08 February 2006 - 11:14 AM
That sentence and cars do not go together, particularly if your considering modifications. Changing parts, easy, modding to something else, hassle and frustration comes into the equation.I was wondering what is a cheap and hassle free option.
#6 _CHOPPER_
Posted 08 February 2006 - 06:07 PM
#7 _the gts_
Posted 14 February 2006 - 11:28 PM
#8 _CHOPPER_
Posted 14 February 2006 - 11:35 PM
#9 _ChiaLX_
Posted 15 February 2006 - 08:33 AM
I converted mine from a four cyl sunbird to V8 17 years ago and found the best way is to find a really rough v8 torana and swap everything over. that way you can see how it is supposed to look and you factory wiring loom for the engine.
It is probably cheaper to do that than source everthing seperate.
PS if you do the conversion be sure to take pics and post them up and ask lots of questions. good luck with it.
Edited by ChiaLX, 15 February 2006 - 08:35 AM.
Posted 15 February 2006 - 09:09 AM
Technically you should upgrade to a V8 shaft and unis but that would involve changing the pinion yoke on the diff. I doubt any inspector would notice anyway.
You can get away with the 6cyl booster, thats all SL spec LH's had.
As the others pointed out, HQ sump, pick up and eng mounts will go straight in. Exhaust manifolds are Torana specific so just get some old pipes.
HQ V8 radiator and hoses are the go, or C/dore V8 if you dont mind a bit of fabrication.
Dont forget the Torana specific alt. bracket, probably the hardest thing to organize.
Dont dream it....DO IT !!
#11 _ChiaLX_
Posted 15 February 2006 - 11:24 AM
#12 _kaz from adelaide_
Posted 15 February 2006 - 11:33 PM
Those extractors etc i won off ebay were spot on, cant quite get a handle on the size difference tho!! I reckon I will have a tear in my eye when I finally get 2 c and hear motor running in existing torrie, current owner says exhaust aren't on, that will get me motor-vated (get it, motor ha ha).
Cant wait, Ruby gets to turn dirty at 30. I am leaning to it being a late birthday pressie for her, her make was 6/76 and that is way too close for comfort.
Any mention of springs, or would the 202 already b set up with the rite ones?? Ruby needs new ones(173>253).
Ps, I do talk as much as I type. XXXXXXX
