Diff Numbers
#1 _smiley_
Posted 06 February 2006 - 04:11 PM
eg:-G95=3.36
Please
Posted 06 February 2006 - 04:26 PM
GU7 2.78
G70 2.60
GU8 3.90
GV4 3.36
GV7 3.55
#3 _smiley_
Posted 06 February 2006 - 04:41 PM
Response time faster than any Goggle search
BUT the ones I`m after are the G9* there isn`t a U after the G..
They don`t actually appear on my plates only on my Holden letter OOP`S
Posted 06 February 2006 - 05:12 PM
#5 _Herne_
Posted 06 February 2006 - 05:47 PM
G92 Banjo 2.78:1 14/39 Uncommon ratio. LSD standard to Brougham
G93 Banjo 3.08:1 13/40
G95 Banjo 3.36:1 11/37 6cyl manual trans economy ratio
G91 Banjo 3.55:1 11/39 Very common 6cyl ratio
G90 Banjo 3.90:1 10/39 Std 6cyl commercial ratio with manual trans
G94 Salisbury 3.08:1 12/37
G88 Salisbury 3.36:1 11/37
G89 Salisbury 3.55:1 11/39 HK and HT only
edited to supply source of info.
http://www.oldholden...ferential_Codes
Herne
Edited by Herne, 06 February 2006 - 05:49 PM.
Posted 07 February 2006 - 11:29 AM
Like "Delete Stripes"
G..
Posted 07 February 2006 - 07:29 PM
It depends which model series you are referring to. The diff option numbers were changed after HQ so as not to differentiate between Banjo & Salisbury.
The list that Herne has posted above applies to HK, HT, HG, HQ, LC & LJ.
The list that REDA9X has posted applies to HJ to WB, LH to UC & Commodores.
Dr Terry.
#8 _ssstone_
Posted 07 February 2006 - 07:35 PM
Posted 07 February 2006 - 07:46 PM
G90 in a 1980 1 Tonner is a bit odd.
A 1980 1 Tonner is either an HZ or a WB & should only have one of those listed by REDA9X or the GM9 which is the 4.44 ratio used in 6 cylinder 1 Tonners only.
The other possibilities are a mis-printed body plate, a body plate taken from an HQ & then fitted to your car, or a G70 (2.60) that can be mistaken for G90.
Dr Terry.
#10 _CHOPPER_
#11 _ssstone_
Posted 07 February 2006 - 08:08 PM
Edited by ssstone, 07 February 2006 - 08:13 PM.
#12 _CHOPPER_
Posted 07 February 2006 - 08:11 PM
#13 _ssstone_
Posted 07 February 2006 - 08:15 PM
imagine how many we could fit on the tray ????FULLY SIK MAAATEIt does, I know by experience. Or just do as the ricers and ad another subwoofer. Problem solved.
#14 _CHOPPER_
Posted 07 February 2006 - 08:18 PM
#15 _ssstone_
Posted 08 February 2006 - 05:11 PM
we could film it and sell it to foxtell as pimp my aussie rideImagine the money we could make. Install a Starfire 4, extend the tray for more subwoofers. 26" alloys would fit in the back no trouble. Only draw back is they aren't a front wheel drive. Otherwise we could be onto a winner.
