Project Fibre Glass Bonnet
38 replies to this topic
#1 TUF 308
TUF 308
  • 169 posts
Posted 03 January 2008 - 07:56 PM
Been a fibreglasser for about 4 years now thought it about time i use my skills to make some moulds for a bonnet for my car. im aiming for around 9kg, will have inner and outer skins.
started today progress so far
Flanges glued onto bonnet flush with top for outer skin mould.
Gelcoat sprayed for mould
Also got the first layer of glass on mould this arvy hopefully finish top mould tommorow then start on inner skin mould on weekend. More pics to come
#2 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 03 January 2008 - 08:10 PM
how many kilos in a steel bonnet?
#3 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 04 January 2008 - 12:28 AM
id love to do this myself, could you explain how its done in more detail?
Thanks mate
#4 rodomo
  • 18,050 posts
Posted 04 January 2008 - 01:10 AM
Some good info here:
http://www.atomicmpc...s=2&c=18&t=1971
#5 GML-31
Posted 04 January 2008 - 07:32 AM
hes only on the start of it.... will need a lot of bracing on it to stop it distorting, helped make a lot of molds 20 odd years ago for car kits
#6 TUF 308
TUF 308
  • 169 posts
Posted 04 January 2008 - 02:57 PM
Finished Top mould today. Applied more layers this morning then put ribs on this arvy, so top is all finished. will flip tommorow and start on inner skin mould.
Today:
final layers of glass put on.
Started to lay out the ribs. Using lowdensity foam which is cheap and easy to sand.
Hot Glued on then corners are sanded smooth.
2 layers of 450csm (choppy) applied over ribs. Top mould done apart from trimming.
dont have a exact figure yet but i think around 16kilos
#7 Heath
  • 18,401 posts
Posted 04 January 2008 - 09:51 PM
Yeah I would have estimated about 15kg because they aren't overly heavy. This 9kg bonnet seems kinda heavy to me... I would have hoped for 6-7kg... maybe I was being a bit optimistic. But keep up the good work
#8 TUF 308
TUF 308
  • 169 posts
Posted 05 January 2008 - 07:20 PM
Whoo, finished inner skin mould today. Start making a bonnet monday after a little bit of trimming of the inner mould.
Today
fliped over with flanges ripped off and trimmed up.
all taped up ready for gelcoating
spraying pva which is a release agent so the gelcoat does not bond to the bonnet
gelcoated
tie layer, which is a fine layer of 225csm which wraps around corners better than heavier glass so as not to get air voids. air voids leads to the gelcoat cracking out first time you make a part.
All done. 4 layers of 450csm done 2 at a time so it dosen't heat up to much
looking at it today i think 9 kg might be over estimated. if i dont gelcoat the bonnet i think i could easily make 6-7kg. if money wasnt a issue i would use carbon fibre but at $90 a sq. meter i think ill leave it.
#9 _Bomber Watson_
Posted 05 January 2008 - 08:23 PM
Hey mate, just a quick Q.
I have played around with fiberglass a fair bit, worked for a bloke fixing up the skirts for the tilt train, fixing his speedway car, and now work on trucks where i get to play around with fiberglass bonnets or do repairs in Leaders, where the whole cab is glass.
But every mould i've made i've just used release agent and then glassed over that. The finished product is always pitted etc, so i have to fill it with bog/whatever before i use it as a mould.
Does spraying jell coat over the item before making a mould help eliminate these pits???
Any help appreciated, this is one area i want to improve myself as i have never really been taught, just figured it out on the way!!!
Edited by Bomber Watson, 05 January 2008 - 08:24 PM.
#10 TUF 308
TUF 308
  • 169 posts
Posted 05 January 2008 - 08:53 PM
Yeah mate spraying or even brushing gel coat on before you glass will eliminate the pitting. gel coat coat will give a much better mould surface than glass. gelcoat will also be a easier surface to work with you can just hit it with some wet and dry and give it a buff and it will come up half decent.
Edited by TUF 308, 05 January 2008 - 09:05 PM.
#11 _Bomber Watson_
Posted 06 January 2008 - 12:05 AM
Awesome. Something new to try.
Now i gotta learn to use gell coat lol.
Cheers mate.
#12 _LXChev366_
_LXChev366_
Posted 07 January 2008 - 09:22 AM
Well I was curious as to how much a std bonnet weighs... and I have the bonnet off my Racer at the mo and using bathroom scales, I weighed 97.5 kg and when I picked up the bonnet it said 119kg, so thats 21.5 kg. Mine has 2 small bonnet pins so delete 300 - 400 grams?
#13 TUF 308
TUF 308
  • 169 posts
Posted 07 January 2008 - 05:51 PM
Looks like we where a bit out with the weight of a standard bonnet, weighted it today
Very close Lxchev i got 22kg. so yeah heaveir than the 16kg i thought.
Progress today
Demoulded in the morning
outter skin mould came up great
all trimed up, also came up good
inner skin glassed
also did top skin didnt get a photo. will be gluing together on friday trimmed up saturday ready to be weighted
#14 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 07 January 2008 - 06:11 PM
Carbon fiber next?
#15 _Bigmac123_99_
_Bigmac123_99_
Posted 07 January 2008 - 06:32 PM
will you be considering orders cheaper then the other available supliers?? i am after a bonnet but i cant justify spending $450 yet.
#16 _Baronvonrort_
_Baronvonrort_
Posted 08 January 2008 - 10:35 AM
Carbon fiber next?
He could substitute carbon cloth for the CSM and cannot upgrade to higher quality epoxy resin as epoxy needs more heat to set.He could put a core in and vacum bag it which would make it lighter using same resin/cloth.
A proper carbon bonnet will need the mould to be made from similar materials as expansion rates between mould and product have to be similar.A sandwich type construction would be the way to go using either foam or nomex and this would have to be vacum bagged and if a pre preg cloth is used the lowest temp stuff still needs to be cooked at over 60C for a few hours under vacum and the higher quality pre pregs need over 100c.A bonnet built like this would have panel weight of just under 1kg per sq m and should have stiffness and not require any framing.
#17 _TORANASS_
_TORANASS_
Posted 08 January 2008 - 01:32 PM
Baronvonrort are you sure your not Proffesor Charly Epps?
Thats some great knolage mate.
John
#18 Heath
  • 18,401 posts
Posted 08 January 2008 - 04:19 PM
Baronvonrort, what exactly is "Nomex"? Is that that kind of honeycombe style core that they use in 'sandwitch' construction kinda Carbon Fibre?
#19 TUF 308
TUF 308
  • 169 posts
Posted 08 January 2008 - 06:02 PM
Bigmac123_99 Posted on Jan 7 2008, 06:32 PM
� will you be considering orders cheaper then the other available supliers?? i am after a bonnet but i cant justify spending $450 yet.�
Possibly mate wanna see how the first one comes out and have a bit of a play around with weights keep you updated.
(Bart @ Jan 7 2008, 06:11 PM)
Carbon fiber next?
all of what Baronvonrort said applies. I am kinda limited to what i can do as the moulds could not withstand the baking that prepreg reqiuers. Normal carbon fibre would be ok with vinly ester resin but its just the price of the stuff its so bloody expensive. But my next move maybe a sandwich core, vac bagged which is one of the reasons why i extended the flanges. I have alot of things i can play around with its just finiding the time to do it. I am looking forward to friday + sat when its all finished.
Edited by TUF 308, 08 January 2008 - 06:07 PM.
#20 TUF 308
TUF 308
  • 169 posts
Posted 11 January 2008 - 06:46 PM
Glued together today
pop it out morrow, trim up, tap holes, done yay :D
#21 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 11 January 2008 - 06:51 PM
Bloody excellent job is all i can say!
Thanks for the pictures too, this should really be in the tech section! :spoton:
#22 _adrianj_
_adrianj_
Posted 11 January 2008 - 09:10 PM
u make me one?
#23 TUF 308
TUF 308
  • 169 posts
Posted 12 January 2008 - 06:25 PM
Tiny Posted on Jan 11 2008, 06:51 PM
Thanks mate :spoton:
adrianj Posted on Jan 11 2008, 09:10 PM
  u make me one?
hehe, i wanna make sure there good before i start makin em for other people get a few wrinkles ironed out.
Well its is finished i was so exicted this morning when i poped it out, it was so light :) trimmed it up then weighted it. 7kg it came in at which i am really happy with. its so easy to lift by myself, just have to be careful when the wind picks up as the bloody thing takes off a little. haven't had a chance to fit it to my car yet, am going to take springs off the hinges and maybe fit a gas strut anyone done this?
anyway pics
all up i spent about four 7 hour days makin the mould, and 3 days makin the part.
#24 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 12 January 2008 - 06:39 PM
Looking Good!
it wouldnt be too hard to do a CF one, and you wouldnt need a brace on the inside, you could just run a layer of sandwich 50mm wide under the edges and a sandwich cross from corner to corner. for the canopies/farings we used to make we used vinylester resin to keep the costs down but for the spaceframes we used epoxy.
Did I mention I used to make Carbon-Kevlar tubing, that was good fun!
Edited by makka, 12 January 2008 - 06:40 PM.
#25 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
How does it go for stiffness compared to the steel bonnet?
Also do you know if it's legal to use a glass bonnet on the street? It's bloody good an an easy weight saving! The way youve done the bracing i think it would be hard to tell!
