lc/lj v8 conversion
#1 _ultrabluea9x_
Posted 17 November 2005 - 11:03 AM
i need to know what parts to buy (sump, eng mounts,extractors bla bla)
#2 _majuva33_
Posted 17 November 2005 - 12:16 PM
Mark
#3 _rorym_
Posted 17 November 2005 - 12:35 PM
HQ 308 radiator.
HQ V8 engine mounts.
Commodore pass side exhaust header.(points down at 45 degrees)
LH extra knuckle fitted 100mm above cross member.
V8 gearbox shaft.
Cable throttle from LH or HQ.
Throttle pedal to suit. (Gemini is good with a bit of bending)
Std rocker covers to clear booster.
"HI Energy" sump for conversion.(American Auto Parts)
VN - VS hi torque small starter for clearance.
Mix all together then bolt it in.
Done.
Edited by rorym, 17 November 2005 - 12:37 PM.
Posted 17 November 2005 - 02:34 PM
#5 _ultrabluea9x_
Posted 17 November 2005 - 03:06 PM
do you know if this correct?
#6 _rorym_
Posted 17 November 2005 - 04:12 PM
Posted 17 November 2005 - 09:09 PM
#8 _ultrabluea9x_
Posted 17 November 2005 - 11:01 PM
Edited by ultrabluea9x, 17 November 2005 - 11:02 PM.
#9 _rorym_
Posted 18 November 2005 - 04:27 PM
When mods get all the old tech articles up, you can get a fair bit of info of wouldbee's story on it.
Edited by rorym, 18 November 2005 - 04:28 PM.
#10 _rorym_
Posted 21 November 2005 - 05:24 PM
ULTRA, Once you have done it once, it is a piece of p=ss! Pity you didnt live in Qld!
Edited by rorym, 21 November 2005 - 05:27 PM.
#11 _ultrabluea9x_
Posted 27 November 2005 - 10:48 PM
#12 _lcgtr_
Posted 28 November 2005 - 03:15 AM
Any pics you want mate let me know and give me a few days
#13 _ultrabluea9x_
Posted 28 November 2005 - 09:37 AM
#14 _rorym_
Posted 28 November 2005 - 09:57 AM
I am going to use a HT 253/308 alternator bracket.
Standard tailshaft just slips in, tho I have a V8 HQ I am getting cutdown and will fit that with the V8 yoke in the diff. Lots of little things to do on my xmas break!
#15 _ultrabluea9x_
Posted 28 November 2005 - 12:25 PM
#16 _rorym_
Posted 28 November 2005 - 06:37 PM
Tailshaft quote today to shorten and balance the V8 HQ shaft is $121. They want proper measurements to be sure as well as a std one to compare. You will need a V8 banjo yoke, $25 on ebay. As A2 says, get the right unis, grease nipple in the centre of the body, NOT the ones from Taiwan with nipple on the end of the uni head.
#17 _lcgtr_
Posted 29 November 2005 - 10:18 PM
#18 _ultrabluea9x_
Posted 29 November 2005 - 11:20 PM
#19 _SLR_
Posted 02 December 2005 - 07:12 AM
#20 _lcgtr_
Posted 04 December 2005 - 03:01 AM
Ill go a Borg Warner conversion next time. Lightweight, modern design, every ratio available, ready made disc brakes and strong as any of the others.
Plus you can get them cheep. I bought a V8 VL one for $350 from a wreckers complete
