Rang a guy at rare spares and said im doing a manual conversion for a Lc/Lj and was after a manual pedal box. He said you dont need one, just attach the clutch pedal to the firewall.
Has anyone heard of this? Do you think it will work as well?
William
Manual pedal box not needed?
_01dencwe_
, Feb 08 2006 06:47 PM
8 replies to this topic
#1 _01dencwe_
Posted 08 February 2006 - 06:47 PM
#2 _gstar_
Posted 08 February 2006 - 09:35 PM
this wont help you much, but when i was asking around for the same thing, a very dodgey mechanic told me he used a brake pedal in reverse? i got no idea what it means, but its a start to your thread,
like i said, this guy is dodgey as, but he is my prefered mechanic.
#3 _xsteve_
Posted 09 February 2006 - 12:49 PM
Not sure about the torana BUT i did the swap in a VK commodore and after all the pain of getting the auto pedal box out .... ...lol... we found all we needed to do was insert the clutch pedal into the old auto pedal box ( all the mounting was there just needed to slip it up and put in the pin ) *and the brake pedal had to be swaped from the wide(auto) to the thin(manual) pedal to fit the clutch pedal in(same deal pull the pin and change)
hope holden did this to most of there cars
hope its the same for you and your torana
#4 _1QUICK LJ_
Posted 09 February 2006 - 07:15 PM
all the pedal boxes are the same slide the clutch pedal on and put then pin in
#5 _01dencwe_
Posted 10 February 2006 - 05:54 PM
Oh great. Thanks for your help.
#6 _WYLDLC 6_
Posted 11 February 2006 - 09:40 AM
Wish I knew that 18 months ago.
#7 _Bomber Watson_
Posted 11 February 2006 - 02:03 PM
correct. but you will also need the manual pedal (a because it's not huge and b i think the shaft is diferent lengh??? can't remember that bit.)all the pedal boxes are the same slide the clutch pedal on and put then pin in
#8 _gstar_
Posted 12 February 2006 - 01:41 AM
rang my dodgey mechanic, he heated up the brake pedal and bent it backwards, trimmed the pad and found rubber to suit.
great stuff.
great stuff.
#9 _Bomber Watson_
Posted 12 February 2006 - 11:21 AM
thats not so bad really....i don't mind a bit of dodge mechanic work like that personaly, i do it from time to time. it's simply taking a part and making it work with somethign else. so long as it works and is safe who the hell cares???? whats so diferent between making a pedal work like you said and putting a 350 chev into a lj??? both things are taking something and making it fit....
