Hi, with the gear box securing mount, I'm not sure what it's called, it bolts on to the bottom of the box and secures to the chassis - are the two bolts connecting the two supposed to be turned tight or do they stay relatively loose? I need to buy a manual, it's true.
LH/LX gearbox cross member
_Eddie_
, Feb 08 2006 08:14 PM
6 replies to this topic
#1 _Eddie_
Posted 08 February 2006 - 08:14 PM
#2 _CHOPPER_
Posted 08 February 2006 - 08:53 PM
They need to be torqued up to FT*.
*FT = F***en Tight.
*FT = F***en Tight.
#3 _Eddie_
Posted 08 February 2006 - 09:44 PM
They are 9/16 bolt size right? Mine seem not to be tightening. It's doing that merry go round thing. You keep tightening and it keeps spinning like some perpetual nightmare. The threads don't show any sign of burring or cross threading so wtf is going on? Maybe wrong thread size?
#4 _2wild4u_
Posted 08 February 2006 - 10:54 PM
id say you have the wrong bolts, they are pretty coarse
Posted 08 February 2006 - 11:22 PM
Are they the 4 bolts where the "x" member bolts to the chassis rail?
If these are stripped in the rail you must find the next oversize bolt (regardless of original thread (consult you local bolt bloke) and retap the threads and replace the bolts. If it is the 2 bolts to the gearbox mount rubber, replace the gearbox mount rubber. If it is the 2 bolts where the gearbox rubber mount bolts to your gearbox extension housing either replace the extension housing or take to workshop to "helicoil" the threads as it would be more cost effective than buying the helicoil set to fix it yourself.
RACV MAN
RACV MAN
#6 _CHOPPER_
Posted 09 February 2006 - 06:03 PM
No matter what's stuffed, I have spares of all of the above.
Posted 15 February 2006 - 02:57 PM
The bolts that go into the box are 7/16 unc thread, 5/8 spanner head not 9/16 thats why they are not tightening.
