ls1 sumps and engine mounts
#1 _moot_
Posted 07 May 2008 - 05:21 PM
what are the best engine mounts and sump to use?
engine mounts crs Vs cae?
camaro sump Vs sheet metal?
i need bolt in minimal in car fabrication
the pipes will be made by a race car fabricator off a dummy car that he has (he's 4 hours away from me so i cant use that car for trial fitting)
engine will be backed by a glide if that makes any difference
Posted 07 May 2008 - 08:03 PM
I went Camaro sump and modified the X member. I bit of work involved
Launch went CAE sump slight mod to x member (TAP TAP). No work involved. Bolt on, drop the engine in. That easy.
I wish I had gone that way.
PM me if you want more info
Mark
#3 _L_X_Hatch_
Posted 08 May 2008 - 06:58 PM
Posted 08 May 2008 - 10:54 PM
I spoke to High Energy Sumps a few days ago. They are waiting for some new sumps from the States. They been having problems with used sumps and welding them.
I'm not having much luck with one for my lc.
Posted 09 May 2008 - 02:33 AM
Posted 09 May 2008 - 03:22 PM
Adam
Posted 10 May 2008 - 12:38 PM
Posted 10 May 2008 - 11:22 PM
don't think it will fit. Look like to will hit the xmember on the top. I think the rear would fit in.Colin or anyone else.
Have you looked at this sump yet?
Oil Pan
I reckon this one would probably drop straight into any torana...
Adam
I will post some pics of my engine and the xmember and show you why
Posted 12 May 2008 - 09:19 PM
#11 _revmaniac_
Posted 13 May 2008 - 09:16 PM
Posted 13 May 2008 - 09:33 PM
Edited by ls2lxhatch, 13 May 2008 - 09:36 PM.
Posted 14 May 2008 - 06:52 AM
6.5L actually before it gets anywhere near the windage tray.^^ LS1 Camaro pan modified to suit LX will hold around 6 litres. In my opinion the pickup should be further back in the pan.
Pickup is exactly where the camaro sits, only mod was I cut the pickup screen and rotated 90 degrees so it didn't hit the pan.
Posted 14 May 2008 - 08:04 AM
The standard Camaro pickup position is roughly in the middle of the front baffled section of the sump.
Once you cut an inch or more off the front off the sump to clear the crossmember the pickup ends up at the front of the sump in a small baffled area.
Edited by ls2lxhatch, 14 May 2008 - 08:05 AM.
#15 _L_X_Hatch_
Posted 14 May 2008 - 06:58 PM
Posted 14 May 2008 - 07:44 PM
I have choosen another path for an oil system, but thats costing a lot more $$ then $200.
If you want to know how to spend your money on an alternative route PM me and I'll show you how to blow $3000 getting oil pumping thru your engine.
#18 _dapperUC_
Posted 26 May 2008 - 04:01 PM
Posted 26 May 2008 - 04:58 PM
I've had mine for the past 6 weeks already.Gents just a update, i spoke to High Energy today sumps have arrived in but another 3 weeks min to do some R & D work and price structure
Posted 26 May 2008 - 06:30 PM
#21 _Toranamuk_
Posted 05 September 2008 - 10:08 AM
I'm converting an 81 F body Pontiac to LS2 & auto & a LX sedan to LS2 & 6sp
http://www.ls1tech.c...ad.php?t=817787
Hope it helps
Craig
#22
Posted 05 September 2008 - 10:21 PM
Modified Camaro. Sand cast aluminium
The Camaro requires significant modification to fit the LX.
http://ls2lxhatch.com/engine.htm
Canton 13-274A. Fabricated aluminium sheet
I have trial fitted the Canton 13-274A with CRS mounts and found it needs about 10 mm shaved off the bottom to clear the steering rack. When fitted with CAE mounts no modifications are required. Note: The CRS mounts are around 10 mm lower than the CAE mounts.
http://ls2lxhatch.com/canton.htm
Moroso 20140. Pressed steel sheet
The Moroso 20140 has a little more clearance in all the right places so it should fit with the CRS mounts and will definitely fit with the CAE mounts.
http://ls2lxhatch.com/moroso.htm
#23 _Toranamuk_
Posted 06 September 2008 - 01:54 AM
Have you seen or tried the LH8 sump, It appears a bit deeper at the rear & reasonably shallow at the front of the pan.
Interesting air cond braket & compressor, is it the OEM Sanden compressor or after market unit ??
At this stage I'm going to purchase 2 new 2008 CTS-V Cadillac sumps & pickups etc etc, it seems it will fit the F body pontiac & appear to need very little mods for the Torana, although after your pics the LH8 sump maybe closer for the Torana.
Thanks ls2hatch
Craig
#24
Posted 06 September 2008 - 03:34 AM
The Camaro oil pan is 1 3/8" deep at the front, this gives about 10 mm clearance with CRS mounts and around 20 mm with CAE mounts. The LH8 is 3.5" deep at the front so it will require significant modification. Once you have cut the front of the pan the pickup will also require modification to fit in the front of the pan.
The CTS-V pan looks like it is more difficult to modify for the LX than a Camaro oil pan. It is 2" deep at the front vs 1 3/8" for the Camaro. This means it will not clear the steering rack with CRS mounts and clearance would be down to around 5 mm with the CAE mounts. The NCOP specifies a minimum of 10 mm clearance. The sump area would need to be cut back the same as the Camaro.
Once you have cut back the sump area on the Camaro sump you need to move the pickup back so it is centre or rear of centre of the remaining sump. In this picture the standard Camaro pickup has been moved about 50 mm back, I think it could do with being moved a little bit further which may also require a brace. Instead of purchasing and modifying the Camaro pickup the Moroso 24050 pickup may be an off the shelf option, I plan to check this next time I pull the engine. You will also need to fabricate an oil control plate similar to the one in this picture preferably with a baffle and trap door similar to the Moroso and Canton pans.
The Moroso 20140 or the Canton are better options. If you want a sump that bolts to the transmission then the Camaro or the 2007 Monaro would be my choice.
The A/C compressor on my engine is a Sanden 508.
Edited by ls2lxhatch, 06 September 2008 - 03:39 AM.
#25
Posted 06 September 2008 - 10:33 AM
i've fixed my ls1 sump problem. i have Andrew from High Enrgy comming around soon to measure up for for my lc.
