drakey has asked me to ask yas all about a head he might be buying hes not sure if its yella terra or not
the part number is 7429477
cheer, luke
yella terra head?
_high_rpm_
, Feb 16 2006 06:55 PM
5 replies to this topic
#1 _high_rpm_
Posted 16 February 2006 - 06:55 PM
#2 _CHOPPER_
Posted 16 February 2006 - 07:15 PM
That's the casting number GMH installed when it was first cast. It has nothing to do with YT. If you could post some pics of the valves, ports and valve springs, we may be able to give you a good indication of whether it's a YT head or not.
N.B. Not all YT heads have YT stamped into the valves.
Posted 16 February 2006 - 07:17 PM
Sorry you cant tell off part numbers because YT used old holden heads and modified them.
The only way to know is to look at it.
inlet port divider post removed (steel pipe pressed in)
Valves with YT on them (may have been changed)
machining in the valve thoat area
yellow paint (not necessarily but most do as most common was "stage 3" or "Street Performer")
#4 _CHOPPER_
Posted 16 February 2006 - 07:23 PM
YT painted the 6 cyl heads yellow, blue and red, depending on the application.
#5 _high_rpm_
Posted 16 February 2006 - 07:48 PM
oki doki thanks for ya help i will tell him i asked about the valves and ports and he couldnt remember so yeah.. cheers
Posted 16 February 2006 - 07:49 PM
If you get an alloy one it doesn't have paint..easy to pick
12 ports makes it easy too.
have 2 in my workshop ATM...one partially stripped..can post pics.
Edited by FastEHHolden, 16 February 2006 - 07:52 PM.
