Drag Cars
#1 _SIR350_
Posted 17 May 2008 - 05:30 PM
#2 _ChevLX_77_
Posted 17 May 2008 - 05:49 PM
Posted 17 May 2008 - 06:53 PM
EFI or carb, holden or chev, 6 cyl or V8.
Posted 17 May 2008 - 07:24 PM
Posted 17 May 2008 - 07:28 PM
#6 _keith1962_
Posted 17 May 2008 - 09:06 PM
you have to have the gearbox,diff etc.
cheers Keith
#7 _Toranamuk_
Posted 17 May 2008 - 10:37 PM
The engine will cost $XX,XXX.XX
transmission & converter $XXXX.XX
Fuel sytem, tailshaft, diff assy, suspension, exhaust, tyres, etc etc
Craig
#8 _why-psi_
Posted 18 May 2008 - 07:11 PM
Posted 18 May 2008 - 07:24 PM
The engine is only half of it. Convertor, trans and diff as well as fuel system are as vital. 10-11 secs really comes down to an effective combo more than the engine. Yes you can run fast on a budget but it still costs, particularly if starting from scratch.
#10 _ronaldoredsox_
Posted 18 May 2008 - 08:25 PM
#11 _Torana308_
Posted 20 May 2008 - 06:09 PM
My mate has a VK that went 10.90s just before it was sold , It owed him around 50k and thats with alot of work done at mates rates etc.
The other thing is if you build a big dollar engine you need to spend money to get good quality parts to work with it( converter, extractors, carby, ignition system, Diff gears, gearbox, tailshaft) and it all has to work together as a package to get the magic numbers
#12 _OLC383_
Posted 22 May 2008 - 11:34 PM
Posted 22 May 2008 - 11:52 PM
A. as much as you want to spend , development and the desire to go quicker can be an open cheque book
in reality set a budget and stick to it !!!
Posted 23 May 2008 - 12:19 AM
Posted 23 May 2008 - 08:21 AM
Posted 23 May 2008 - 06:53 PM
Then triple it ....... to fix all the stuff upsin reality set a budget and stick to it !!!
#17 _HRV74_
Posted 29 May 2008 - 05:12 PM
Street Machine May 08 (page 132) was pretty interesting. Bob Kotmel states "there are some real bargains available, like the Scott Schafiroff Ultra Street 434-cube small-blocks for $9350 US, with another $1500 to land them here. You can't buy the parts here for that money....."
A few specs are listed and the article goes on to say that they make 595hp.
www.shafiroff.com
Could be an option if you've got the rest of the car to suit. Legality would be an issue though, due to the size of the engine.
Posted 29 May 2008 - 08:19 PM
Thats too cheap. The last Shaffiroff engine I heard about coming over was $3600 for freight, plus GST etc. Ends up a lot more than $1500.Bob Kotmel states "there are some real bargains available, like the Scott Schafiroff Ultra Street 434-cube small-blocks for $9350 US, with another $1500 to land them here.
#19 _moot_
Posted 29 May 2008 - 09:32 PM
$1850, then you get slugged with gst and probably some more expences. i've been looking at them
#20 _Lostit_
Posted 30 August 2008 - 09:49 AM
Best advise which has been stated alrdy.. buy a car where someone is getting married, divorced,dead, etc and they have put in a shitload of money into it alrdy .
#21 _BlownOutlaw_
Posted 30 August 2008 - 12:29 PM
When you say drag car... do you want a 'drag car' or a street drag car ?
The lighter an object the quicker you can push it with less effort.
The cheapest way to run 11 or 10s is to have a real drag car thats not a road car. Remove anything not required thats extra weight. Make plastic windows, remove the window winders etc fibreglass panels. Then you need less power to move it, making engine costs cheaper.
I have some friends that have an LJ 2 door drag car that runs like 9.2 seconds with a 202 6cyl turbo.
A street car will be, heavier, more expensive and harder to work with/on. Street cars tend to be a compromise, eg rear end gearing and stall speed etc, and this makes it harder again to reach your objective.
Its really an open ended question with many variables that will influence the answer.
#22 _Dirty Deeds_
Posted 31 August 2008 - 09:43 AM
I think the main influence as to running good numbers with less cost is weight.
