Oil priming a 308
#1 _holdon_
Posted 08 June 2008 - 11:52 PM
im getting sus on the seal that i forgot to put in between the oil pickup and block. (see my other post - http://www.gmh-toran...howtopic=28181). could this be the problem?
the engine has been sitting for about a year - so it is completly dry (lifters/bearings etc). is the starter motor cranking speed enough to circulate the oil properly?
i have tuned it over about 4 times for about 30secs at a time. i would have thought that id be seeing oil out the rockers by now?
any help appreciated!
thanks
Posted 09 June 2008 - 01:16 AM
#3 _holdon_
Posted 09 June 2008 - 03:01 AM
how else can i check that this motor hasnt got a oil pressure problem without a master guage.
i have fixed my pickup problem so ill have another go in the morning and see if its any better
Posted 09 June 2008 - 08:38 AM
Posted 09 June 2008 - 08:41 AM
#6 _Lostit_
Posted 09 June 2008 - 09:05 AM
But firstly drop the pump off pack the gears with vasoline put it all back and crank it over if all correct yourll get oil pressure show up within seconds .
#7 _torana_
Posted 09 June 2008 - 11:21 AM
#8 _monarodad_
Posted 09 June 2008 - 06:22 PM
This was something a professsional engine builder told me when I had a similar problem.
good luck
Andrew
#9 _Barman_
Posted 09 June 2008 - 08:10 PM
Baz
Posted 09 June 2008 - 09:25 PM
Serious, I told the guy I was having trouble priming my new engine but he didnt buy it, gave me a bullshit look haha.
But the vaso is the only way you will get pressure on a 253/308, they are a nightmare to prime otherwise. Pack it with vaso and presto you will have psi.
#11 _holdon_
Posted 09 June 2008 - 09:30 PM
I haven�t got a mechanical gauge but I should be able to put 12V on to the sender with a light bulb and it should light up when I get pressure - how much pressure I wont know but at least I know its working for when I start it up and check against the dash gauge......
ill pack the oil pump with some vaso and try that.
The compressed air is a good idea. Failing ^ ill try this too.
Thanks again for the input!
#12 _v8slrtorana_
Posted 09 June 2008 - 09:38 PM
With a empty sump, PUMP (using a hand pump) oil from the drum into oil pump via the oil pressure sender.
This will fill your engine and see full oiled top end on a motor that has never fired
#13 _brutass08_
Posted 09 June 2008 - 10:19 PM
Posted 10 June 2008 - 06:25 PM
Mort
#15 _The Stig_
Posted 10 June 2008 - 10:16 PM
Another thing I was told by a very experienced engine builder, while trying to diagnose the problem, was that the best way to prime the filter is to unscrew it a bit, wind the engine over till oil leaks out around the threads, then tighten it up. Not sure what his reasoning was, and I've never tried it, but thought I might just pass on the info.
BTW Vaso works, I've used it countless times (In oil pumps that is!), and pressurising the sump does work too, although I'd use that as a last resort. Too easy to damage a seal and create oil leaks IMHO.
#16 _Lostit_
Posted 11 June 2008 - 06:18 PM
Dont undo the oil filter and crank a little to make sure.
A little dirty hands and all done as i said before take the pump off( few minutes ) jam it with cold vas not boiled.
Oil filter really should take about 10 minutes to fill up properly when on the bench.Fill the filter up let it settle down, fill it to the top again let it settle down, as i said will take 10 minutes at least to do it properly .
The tricky part with holden v8 is the point where you underneath the car and rdy to put the filter back on... its like get in postion and as fast as you can wind the filter up before it leaks out.
Remeber 99% damage done is on startup to motors.. let alone brand new ones .
You really shouldnt be cranking a brand new motor over once the heads are on, every time you crank it the wipe a little grease/oil off important parts.I know it doesnt sound like much but I prefer my motors lasting a long time .
Posted 12 June 2008 - 12:25 AM
What are the pros and cons of each ?
At least you don't have to go to the chemist to buy grease !
Posted 12 June 2008 - 08:24 AM
My mate had this problem with his 308, he got some Honey like Oil that he was going to use... But eventually got pressure by just turning it over and over and over! LOL
#19 _gtr2600S_
Posted 12 June 2008 - 09:08 AM
These are all interesting threads. I've never used the vas/grease method as most pump manufacturers don't recommend it - apparently the added load on the drive has lead to shears in the past (6 cyl engines anyway) - then you're in the poo. According to your thread, the filter is full of oil so assuming that the cranking has filled the filter, then you shouldn't have any problems or the need to pack the pump - it's already pumping! Once the filter is completely full, then there the oil will find it's way to the bearings and lifters etc. in a matter of seconds. As far as pumping it to the top, generally if the motor was running, it still takes a min or so to get it up to the rockers, so if you're cranking over by hand, you'll be there for years trying to get oil up there.im trying to get oil pressure with my 308 before i put it in the car. I've been cranking it over with the starter and i have not noticed any oil come out of the rockers. the oil filter is full so i can assume the oil pump is working?
thanks
As far as the oil pick up seal - it'll be worth your while to remove the sump, pump etc and fit it. You'll be sucking air in there.
Posted 12 June 2008 - 02:14 PM
Always leave the vaso in till the first 500 to 1000Km change but have never seen it come out
I think grease may be a bit course compared to vasoline.
As for cranking forever I think the damage is done, any bearing lube you have put in there would have vanished.
#21 _Lostit_
Posted 12 June 2008 - 05:00 PM
hehe no mate packing the oil pump itself not the oil filter heheh.
#22 _gtr2600S_
Posted 12 June 2008 - 05:14 PM
http://en.wikipedia....Petroleum_jelly
#23
Posted 12 June 2008 - 05:17 PM
#24 _gtr2600S_
