I have a replacement manifold (as I was using the old one from my 138 to run my 202 on). The new manifold however does not have the holes for the water pipes to go into.
What is the purpose of the water running thorugh the manifold? is it to just warm it up a bit? or cool it down ... is it a problem if I was to just forgo this and not have water going into the manifold and just block off the pipes that are there already?
EDIT: Oh and another thing, I plan to use the carby that came with this manifold as my old one is a bit dodgey. The stromberg on this newer manifold is slightly different and has a series of labelled pipes on it ... obviously dist. is for the vacum in the distributor, but what are 'CAN.' and 'ERG.' for?
On that note, there are also two other extra unlabelled piping holes on it (one larger than the other).
-Al
Edited by LC2250, 20 February 2006 - 03:03 PM.
