Holden 6 secrets, anyone got any to share?
Posted 04 July 2008 - 07:00 PM
Just wondering if anyone has any Holden 6 secrets to share, what to do to make them last etc.
There was a great article posted awhile back about some interesting oil mods, drilling and taping into the side of the block and adding some extra lines etc.
Something about a Massey Ferguson tractor balancer.
I'm building up a 202 at the moment for a turbo build and figure I may as well do some of these things while I have the chance. The oil mods sound interesting and wouldn't mind hearing a bit more about em.
Here is what I have so far.
Discard fibre cam gear if still fitted and replace with alloy gear.
Replace plastic dizzy gear with steel gear which can be obtained from a Holden 6 oil pump. Some people say this can increase cam wear?
Front oil gallery welsh plug. Tap this and fit a grub screw. Just heard about this one, does the welsh plug have an issue with popping out?
So what things would you do?
Hopefully this will become a useful thread. Just like many others on this forum.
_revmaniac_
Posted 04 July 2008 - 10:22 PM
modified 308 oil pump gears in the 6 cyl housing....shortened i think
SBC valve springs...need head machining AFAIK
302 rockers.....higher ratio supposedly....unsure of windsor or clevo
this stuff i know for sure...
reds LOVE lift.....
obvious stuff like good quality oil and filters changed REGULARLY like 5000km...NO MORE
get the right waterpump...sticky on here somewhere about factory ones SH$TTING all over cheap ones...
quality machining...if everything lines up right its free HP and less wear......
TUNE IT RIGHT.....rich engines wash bores and wear quickly...the oil is contaminated prematurely
and if you happen to be running roller rockers you can restrict the oil to the topend leaving more for the hard working bits downstairs
_@milco@_
Posted 05 July 2008 - 12:22 AM
_Brad1979UC_
Posted 05 July 2008 - 12:24 AM
Ive head that this isnt a good idea...it makes sense...as ive had my gear strip in the middle of SA and VICReplace plastic dizzy gear with steel gear which can be obtained from a Holden 6 oil pump. Some people say this can increase cam wear?
Ive head that Ecotec V6's have factory roller rockers and that they bolt onto a red 6...bit skeptical, got told this by a bouncer when i rocked up toa party, so i really got no idea if you can do it or not.
Edited by Brad1979UC, 05 July 2008 - 12:25 AM.
_mervex_
Posted 05 July 2008 - 08:17 AM
Edited by mervex, 05 July 2008 - 08:21 AM.
Posted 05 July 2008 - 11:26 AM
_mervex_
Posted 05 July 2008 - 02:03 PM
Posted 05 July 2008 - 02:09 PM
Posted 05 July 2008 - 04:00 PM
Tends to create a missfire at higher rpm as things start chattering, mainly with HEI ignitionsIve head that this isnt a good idea...it makes sense...as ive had my gear strip in the middle of SA and VICReplace plastic dizzy gear with steel gear which can be obtained from a Holden 6 oil pump. Some people say this can increase cam wear?
...however i cant remember why its not a good idea...it may have been cam wear but i think there was another/other very valid reason.
Edited by Bomber Watson, 05 July 2008 - 04:00 PM.
_202LX_
Posted 05 July 2008 - 04:21 PM
_waratah_
Posted 06 July 2008 - 02:10 AM
Edited by waratah, 06 July 2008 - 02:10 AM.
_mumstaxi_
Posted 06 July 2008 - 09:45 AM
Ive seen twin carby set ups , but triples on a "Turbo" 202, (LOL) id like to see that one !If your going for a big cam, our experience is triples go much fraken harder than any holley.
Be carefull with big cams and Turbo engines, as BIG is not always better and can actually make car slower (this from experience)
202 + Turbo + NOS =
MT
_gtrtorana_
Posted 06 July 2008 - 09:57 AM
_mervex_
Posted 06 July 2008 - 12:49 PM
Edited by mervex, 06 July 2008 - 12:50 PM.
Posted 06 July 2008 - 01:41 PM
Posted 06 July 2008 - 05:09 PM
Im gonna try a big cam with SU's 3/4in on my motor.... hopefully it turns out good but only problem is Fuel but worth itIf your going for a big cam, our experience is triples go much fraken harder than any holley.
_gtrtorana_
Posted 06 July 2008 - 05:50 PM
From my experience, the triples are pretty fuel efficient unless you open the throttle wide open. I had an engine that had both a single Holley and a set of 1.75 Strombergs at one stage or another and the triples overall were beter on fuel than the single crab.Im gonna try a big cam with SU's 3/4in on my motor.... hopefully it turns out good but only problem is Fuel but worth it
_gmlj6_
Posted 06 July 2008 - 06:00 PM
Posted 06 July 2008 - 08:20 PM
_why-psi_
Posted 06 July 2008 - 09:59 PM
#21
_tyre fryer_
Posted 07 July 2008 - 02:09 AM
WOW! this must have been an otherwise free flowing motor. I mean those weren't really gains that was just freeing up power that you had but were restricting right?ive found that a good head and exhaust is the key. i gained 24rwkw from changing from cheapo extractors to a nice set of genies
still, awsome advice for anyone looking to make a serious red 6.
#22
_Brad1979UC_
Posted 07 July 2008 - 02:49 AM
#23
_gmlj6_
Posted 07 July 2008 - 06:11 PM
#24
Posted 07 July 2008 - 06:54 PM
Any recommendations will be greatly appreciated GTR469
#25
_gtr161s_
Posted 07 July 2008 - 09:10 PM
I think you could buy an after market one but they were really expensive
