Rear Crossmember - LJ XU1
Bazza
, Feb 21 2006 08:55 PM
6 replies to this topic
Posted 21 February 2006 - 08:55 PM
Hi Folks
The rear crossmember on my car mounts directly onto the frame on each side with two bolts after passing through a rectangular spacer about 1/4in thick. There is no rubber dampening (except under the extension housing of course).
I notice on eBay an LC LJ crossmember that appears to have metal and rubber devices on the ends of the crossmember. Is this peculiar to all LC/LJs? Is my car supposed to have this type of mounting?
http://tinyurl.com/fl7ot
Any help appreciated
Bazza
Bazza
#2 _bundy black_
Posted 21 February 2006 - 09:34 PM
Bazza
Just pulled the gearbox out my LC and mine where metal, welded to the crossmember.
Posted 22 February 2006 - 09:04 AM
Does anyone else have a comment on this issue? It has me puzzled - perhaps it has some bearing on why my gearchange rods occasionally hit under the floor in the tunnel?
Any comments welcome
Bazza
Bazza
#4 _draglc_
Posted 22 February 2006 - 10:02 AM
My crossmember just bolts straight to the chassis rails, no spacers or rubber mounts at all. I never had a problem with linkages hitting the tunnel?
A1
A1
#5 _gm3300_
Posted 22 February 2006 - 10:15 AM
Bazza said
the one i took off my parts car, auto 3/70 LC, had the rubber mounts on either
end, i'll check the parts book and get back to you
grant
This is exactly the same as my 6/72 GTR, later cars have a wider crossmember,The rear crossmember on my car mounts directly onto the frame on each side with two bolts after passing through a rectangular spacer about 1/4in thick. There is no rubber dampening (except under the extension housing of course).
grant
#6 _gm3300_
Posted 22 February 2006 - 10:33 AM
just checked the parts book and the only reference to
the insulator and bracket is for Auto models.
grant
grant
Posted 22 February 2006 - 11:41 AM
Thanks everyone - I guess that's the definitive answer. Outer rubber mounts are for use on autos. The eBay one had me puzzled because he specifically mentions for use with Aussie 4 speed.
Perhaps one of my gear shift linkage rods has a kink in it.
Bazza
Bazza
