Does anybody know how many teeth are on a Th350 output shaft so i can work out my speedo calibartion.
JNR_ATE
TH350 OUTPUT SHAFT
_JNR_ATE_
, Feb 21 2006 11:46 PM
4 replies to this topic
#1 _JNR_ATE_
Posted 21 February 2006 - 11:46 PM
Posted 22 February 2006 - 10:01 PM
The output has a 27 spline shaft but not sure what the sure how many teeth the speedo cog on the shaft has.
What im trying to say is on the output shaft you have 27 spline, where the slip yoke goes, now a bit further up where your speedo gear mates up there is another angle spline, not sure what count this has.
#3 _TORANASS_
Posted 22 February 2006 - 11:01 PM
I thought T350's had a 28spline outputshaft..
John
John
Posted 22 February 2006 - 11:04 PM
Correct me if i'm wrong but the splines on the output shaft woudlnt matter to speedo calibration....
Bes to count teh teeth on the gear on teh speedo drive to work it out.
#5 _JNR_ATE_
Posted 23 February 2006 - 12:43 AM
i asked chop to helpfully try and work out wat speedo gear i need to get it at least close to being right.
said he needed to know how many spline the output shaft was.
wat im trying to work out is.
1: 3.55 diff ratio with 215/65/15 into a TH350
and
2: 3.08 diff ratio with 265/45/17 into a TH350
How many tooth gear do these calculations need please if anyone can help.
JNR_ATE
and
JNR_ATE
