Air Filters
Posted 22 February 2006 - 10:41 AM
I am looking at tidying up the engine bay of my '72 LJ and was thinking a new chrome air filter to replace the standard Holden one on top of my Red 173 (completely stock) might be a good start but have no clue what to go for. All I know is that the carby is the standard Holden 1bbl (Stromberg??? ). Any help is much appriciated.
Cheers,
Mick
Posted 22 February 2006 - 10:52 AM
If it says "suit standard red six" then it'll probably fit, or send them a message asking whether it will suit your standard single-barrel Stromberg. Not sure about LC/LJ, but I had suprisingly little clearance between the chrome housing and the bonnet, even with the filter that came with it... I wouldn't want to go any shorter than that filter too.
PS I can measure the width of the barrel on my Stromberg if you'd like. Mine isn't the original carb, it's slightly smaller, from a HQ that the engine came out of. I imagine the diameter of the barrel at the top is still the same however.
Edited by Heath, 22 February 2006 - 10:57 AM.
Posted 22 February 2006 - 12:09 PM
Thanks again, should be right to measure mine when I get home from work.
#4 _Keithy's_UC_
Posted 24 February 2006 - 01:47 AM
My K&N filter and the chrome element cost $140, this is because they want to make their money - i wouldnt imagine making a K&N filter would cost that much, but the chrome element cover is genuine metal, not plastic with chrome paint!! If you want to save money in the long run - get a K&N filter as they are re-usable and flow better than any standard paper filter ever would!
Keith
#5 _73LJWhiteSL_
Posted 24 February 2006 - 10:05 AM
I got an orginal air cleaner, pulled the 'silencer' off and stuck the top in a Lathe and remove the whole side of it. I sand blasted it at dads work and then resprayed it Gloss Black. Then I purchased a UniFilter Element and stuck that in.
Result
Total Cost about $15 for the air cleaner, $10 for paint, about $50 for the element.
Steve
Posted 24 February 2006 - 03:44 PM
- Mick
Posted 24 February 2006 - 03:57 PM
It is all standard holden using a "Starfire" 4 cyl aircleaner. Note the big snout. (Bigger than V8) It uses an original element.
I also got the boot and duct for the air cleaner to fit later (this will mean extending the breather from the top of the rocker cover) and run them around the battery to behind the radiator support for cold air induction. I have also got the hot air duct connected and working for cold starting.
Air cleaner and ducts $27 from pick a part
Element $7.22 from bursons
Not as smart looking as chrome but more practical and more effective than full open A/C I hope.
RACV MAN
#8 _devilsadvocate_
Posted 25 February 2006 - 12:27 PM
Posted 25 February 2006 - 12:36 PM
Posted 25 February 2006 - 12:40 PM
What other reason?
Induction noise is in front or the driver and moves backward as you drive similar to exhaust noise. With the star fire A/C they included the cold induction to out perform the Coronas with the same engine. The enclusion of the ducting not only improved performance but but muffled it as well with the duct length.
Remember cars a built for drivability (including noise) rather than performance for the average punter.
RACV MAN
Edited by rodomo, 25 February 2006 - 12:46 PM.
Posted 25 February 2006 - 12:52 PM
I read somewhere and if you think about it I would reckon they were right. That A the induction air would not be as cool as air coming from the direction of a standard snout (any model) and B an open A/C can cause a reverse venturi effect as the air can pass over the airhorn and travel out the back of the A/C. The ideal situation being to pressurise the A/C box marginaly.
RACV MAN
Edited by rodomo, 25 February 2006 - 12:58 PM.
#12 _devilsadvocate_
Posted 25 February 2006 - 04:01 PM
The snorkel you have is off a 4 cylinder commodore?
Posted 25 February 2006 - 05:27 PM
RACV MAN
#14 _devilsadvocate_
Posted 26 February 2006 - 06:32 AM
There was an article in a australian mag about finding the right spot to put the intake for the induction......apparently just sticking it anywere at the front of the car could be worse than doing nothing.......areas of minimum and maximum pressure can build up even at the front is the reason given. Has anyone got this article or know how to find these spots without needing sophisticated equipment to measure the pressure?
Posted 27 February 2006 - 01:11 PM
Behind the headlight, eg most std cars, does nothing due to the convoluted air, and a pod filter screws up the flow.
Hence every Street Commonwhore reader who puts a pod on or out thru the radiator support.........
Grant..
