Chev 350 or 308
31 replies to this topic
#1 _Marshall_
_Marshall_
Posted 27 July 2008 - 07:03 PM
I've been speaking with a few people, both on and off this forum. About my plans to put either a Holden 308 or a Chev 350 into my LX hatch.
It's currently 50/50 on the pro's and cons for each engine install.
Is it really that hard to install a Chev 350. I honestly thought it would be easier as it's a smaller engine. I'll be buying either a Supra or a Tremec 5 speed from a specalist store, so I'll also be buying all the bits and pieces for the gearbox to suit the engine and car (eg bellhousing etc) .
I'll also be buying all the extra bits too, i.e. radiator, exhaust etc.
So my question is " Is it really that hard to install a Chev 350 in a LX hatchback compaired to installing a 308 "
Cheers,
Edited by Marshall, 27 July 2008 - 07:06 PM.
#2 yel327
  • 13,724 posts
Posted 27 July 2008 - 07:52 PM
It's not all that hard, but not as easy as a 308 especially in post 6/76 (or thereabouts) LX ie with ADR27A. Why not build a 308 stroked to 350 or 377? VN heads are pretty cheap and work as well on a 350 cube 308 as any stock or iron headed Chev head does on a SBC. There are twin plane manifolds around for these now too. And all the mounting gear is standard Torana ie mounts, radiator etc
#3 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 27 July 2008 - 08:09 PM
never heard of a 350 stroker im building a 355 i had a simialr problem with deciding i did a pole a while back if you can find it
#4 RIM-010
RIM-010
    DON'T PANIC
  • 8,079 posts
  • Name:Tim
  • Car:LJ 2 Door - HQ Premier
Posted 27 July 2008 - 08:12 PM
I may be wrong but a 350 stroker is a stroked 308 that hasn't been bored 60thou? And a 377 ends up a 383...
Tim
#5 _moot_
_moot_
Posted 27 July 2008 - 08:41 PM
a 355 is a 304/8 bored 30 thou with a 3.480" stroke or a 350 chev 30 thou over. a 377 is a 400 block 30 thou over with a 3.480 stroke. a 383 is 4"+0.030" over bore and a 3.750" stroke. (so holden or chev)
short story use a holden engine upto 500hp,use a chev after that :clap:
Edited by moot, 27 July 2008 - 08:43 PM.
#6 _Marshall_
_Marshall_
Posted 27 July 2008 - 08:46 PM
I'll be happy with 400bhp, 400hp at the wheels would be even better
#7 _moot_
_moot_
Posted 27 July 2008 - 08:51 PM
400hp flywheel= holden.
400rwhp is 550+ at the flywheel. use a chev.
#8 yel327
  • 13,724 posts
Posted 28 July 2008 - 08:27 AM
A Holden 350 stroker 308 is simply a 308 with a 3.48" stroke crank ie a 5.7 as per the VR-VT versions. A Holden 377 stroker is a 3.75" stroke crank in a 308 - the Chev equivalent is a 400 crank (3.75" stroke) in 4" bore block. People often incorrectly call these 355 or 383, but that is at an overbore of 0.030". If you use 20 thou or 40 thou they are wrong. You don't hear people going around calling a 30 thou up 308 a 311 or whatever it is, or a 202 a 206.
And as for Holden only good up to 400hp and Chev over that, make sure you use a good quality Chev block and aftermarket heads. A normal 2 bolt Chev block is not that much better than a 308 block strength wise.
I love Chevs and if you have to buy everything it won't be much dearer at all to go Chev - a brand new 300hp crate motor is only about $2800. Just the 308 stroker is a bit easier ie it was designed to fit, and easier to sneak past rego especially if you have ADR27A.
#9 _lx5008_
_lx5008_
Posted 28 July 2008 - 10:25 AM
marshall. contact lxsstorana he may have his big hp 350 and tremec for sale out of his hatchback soon.
#10 orangeLJ
Posted 28 July 2008 - 10:28 AM
LS1 or LS2... Thats the route i would be taking if i was V8ing a big torana. They are relatively cheap and plentiful, and make HP with ease.
#11 _moot_
_moot_
Posted 28 July 2008 - 12:25 PM
^^^ until you look at all the costs realistically.
it just depends on how much power you want. 500hp on a holden engine will be cheaper than a chev. over 500hp,it'll turn around. lsx engines will make 500hp with a cam and exhaust,but after that there big dollars too.
#12 orangeLJ
Posted 28 July 2008 - 01:15 PM
Bolt on centrifugal kits are making some pretty impressive figures on stock internals.
N/A wise, most make around/just over 200kW at the wheels in stock form
And if you can do the majority of the work yourself, then the costs are dramatically reduced.
The major cost I can see is the engineering, but he will have to follow that route for the 350 anyway.
#13 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 28 July 2008 - 06:02 PM
Sorry to disappoint you but I'm keeping the 350 and tremec. I can't wait to get it going and have some fun with it.
Regards Mick.
#14 _moot_
_moot_
Posted 28 July 2008 - 06:08 PM
a blower wont be legal as it'll put you straight over the capacity to weight limits.... and chevs 'bolt in' with off the shelf parts ls engines wont even come close.even if you do it yourself,an ls engine conversion will cost a shit load.a sbc can be done in half a day....
#15 _Marshall_
_Marshall_
Posted 28 July 2008 - 08:38 PM
Cheers guys it might have swayed slightly more to a 308.
I'll contine to investigate my options but the 355 stroker does sound tempting. I found a nice article in "Perth Street Cars magazine Vol 15 No3"
Vn heads, hypereutectic pistons. Harrop crank, Crane cam, Harrop single plane manifold, 750HP Holly.
This kind of set up apparently should be good for 430ish HP or a 12sec car
Blower is not an option at this point in time. But I would concider gassing it.
#16 _SLR Goat_
_SLR Goat_
Posted 30 July 2008 - 05:17 PM
Just make sure u steer clear of the pro comp stroker kits and alloy heads if u go for the 355 route
#17 Evan
Evan
  • 1,287 posts
Posted 02 August 2008 - 02:22 AM
hey marshal
taken from this good thread, a basic breakdown of going chev.
http://www.gmh-toran.......&hl=toranaz
Engine $2030
th350 $750
Stally $380
Crossmember and speedo cable $195
Extractors $530
He Sump $360
CVR starter $308
Tailshaft and yoke $300
engine brakets + mounts $100
auto dipstick $30
B&m Mega shifter $310
Aftermarket oil cooler $33
V8 king springs $105
V8 uc Booster $95
New ball joints $50 + $30 installation
Gilmer belt pulley drive $170
Total: $5776
togo:
Exhaust will cost $150
Air filter
Fuel fittings
trans oil lines
rear springs
smaller dizzy!
If anyone is thinking about doing the conversion this will give you a pretty good idea what is required.
Evan .
#18 yel327
  • 13,724 posts
Posted 02 August 2008 - 08:58 AM
Plus:
Radiator - $500 (for a 350 a 4 row minimum);
Shroud or properly done thermos - $150 minimum;
Longer starter lead - $75;
Change to bigger brakes as will probably be required to pass Engineering - starts at $600 do it yourself;
Engineering (if the engine isn't a 302/305/307) - $300 or more;
#19 _moot_
_moot_
Posted 02 August 2008 - 02:36 PM
a chev wont run any hotter than a holden engine. and i dont know where your getting your prices from,but i suggest that you may want to shop around :)
#20 yel327
  • 13,724 posts
Posted 02 August 2008 - 04:07 PM
A 350 Chev may not run hotter than a 350 Holden but it DEFINITELY will run hotter than a 308 especially with cast iron heads. A 3 row is simply not good enough.
Prices, well they are estimates and I've been playing with Holdens since the early 1980's so I know what stuff is worth:
$500 for a 4 row radiator (example http://www.aussiedes...catalogue.htm);
$150 for a SBC into HQ radiator shroud under-estimated (example https://rsp-secure.c...a...20HX HZ WB). Plus of course a viscous fan;
$75 for 50 or 70sqmm flexible battery leads, lugged ready to go is cheap;
$600 for brakes - HQ Rotors $200 pair, bearings $65 pair, calipers $60 for the pair, caliper rebuild kits $80, redrill discs to torana pattern $80, new brake hoses $40, new rear wheel cylinders $60, brake fluid $15. Close enough to $600 and only the minumim is done. You should really be fitting HK-HG rear drums as well. Might be slightly cheaper if you used HG front discs as they won't need to have the stud pattern changed.
#21 MRLXSS
  • 12,416 posts
Posted 02 August 2008 - 04:42 PM
I like the idea of keeping it Australian... That is a massive factor that has swayed me to stay with the 308/355 thing... Always good to know that whats under the bonnet is Australian!!
#22 _moot_
_moot_
Posted 02 August 2008 - 04:47 PM
engine capacity does NOT make a car run hotter.
the last 4 core radiator i got was $280.. (factory hq ones are 3 core...) dba hq brake rotors are $48 each,battery cable is cheap as buy the metre($10),lugs are next to nothing...
on a budget,radiator can have the outlets changed to opposite sides
engine mount adapters are $50
hq style sump is next to nothing second hand,
gearbox,convertor and tail shaft are all the same as the holden engine.
extractors are all shit anyway and should be made (tell me you'd use manifolds on a holden engine?)
brakes and other parts should be done if its a chev or a holden.so it doesnt really count as the expenses are the same.
so,extra expenses for a chev over a holden:
sump? (maybe $ depends what you get on the engine to start with)
engine mount adapters$50
starter motor (which you need one converting from a 6 to a 308 anyway so it doesnt count)
radiator $50 to get outlets changed.
alternator bracket ($50 or depends on what you use)
extractors (you'll need for both engines anyway)
difference in cost=bugger all.
#23 _BCR42Y_
_BCR42Y_
Posted 02 August 2008 - 06:00 PM
Thought I would add in my thoughts to this;
I had always been a strong believer of only a Aussie motor in a Torana, and thats why I kept my car a 308 based car, however I have to say a VN headed motor in a LH engine bay is a pain to work on in my opinion, and there is so little room around the rails, steering, booster etc.
After recently seeing so many sbc Chevs in engine bays of LH/LX's and how easily it looks to work around them, if I was to build another Torana, I can safely say that for this reason I would go Chev, the money I put into my motor I know I could have built and installed a Chev motor with easy another 150hp.
#24 TerrA LX
Posted 02 August 2008 - 07:44 PM
Im not entirely agreeing with the whole ideology behind the need for a bigger radiator but one fact is the more power an engine produces, the more heat it produces, regardless of CID.
#25 _ChevLX_77_
_ChevLX_77_
Posted 02 August 2008 - 09:23 PM
What if the engine was running on alcohol????
I dont know about the radiator my chev has a three core and it runs way to cold, 60 degress
BCR 42Y wait till you have to do plugs in a chev powered one!
Edited by ChevLX_77, 02 August 2008 - 09:26 PM.
