I Pulled all the linkages off cleaned them up, set all the idle screws on the carbs then put the linkages back on and adjusted them so that the throttle on each carby was touching the idle screws. Then I used a bit of pipe in the carby and listened to the sucking noise of first and second carby and adjusted the linkage untill the first and second carby sounded the same and locked them both off. Then I listned to the second and third carby and adjusted the linkage on the third carby until it sounded the same as the second.
Can anyone give me any hints or tips for tuning them?
Les
Edited by mrlctorana, 24 February 2006 - 10:39 AM.
