Vp Commodore No Fuel Pump
Posted 29 August 2008 - 10:09 PM
Got a hard one, Vp commo V8 Efi engine cranks got spark but the fuel pumps dont run or even prime checked Relays replaced ignition module replaced dizzy (All had to be done anyway) three different Ecu's still nothing any hints tips etc? Im goin to start back probin n runnin round wit test light tommoro so any pointers be good!?
By the way just to make this a real hard one all the the running gear is an HZ.
Ed
_evil UC hatch_
Posted 29 August 2008 - 10:14 PM
Posted 29 August 2008 - 10:21 PM
Posted 29 August 2008 - 10:31 PM
Posted 29 August 2008 - 10:34 PM
Posted 29 August 2008 - 10:38 PM
Posted 29 August 2008 - 10:40 PM
I can drop it in.
PM me your ph. no.
_evil UC hatch_
Posted 29 August 2008 - 10:41 PM
has this setup been running before or are you in the process of getting it going?
Edited by evil UC hatch, 29 August 2008 - 10:45 PM.
Posted 29 August 2008 - 10:44 PM
_evil UC hatch_
Posted 29 August 2008 - 10:47 PM
Posted 29 August 2008 - 11:23 PM
Posted 30 August 2008 - 07:49 AM
_lx-304_
Posted 30 August 2008 - 09:19 AM
_lx-304_
Posted 30 August 2008 - 09:37 AM
_shibby_
Posted 30 August 2008 - 06:04 PM
_lx-304_
Posted 30 August 2008 - 06:37 PM
Posted 30 August 2008 - 07:58 PM
_luv the uc_
Posted 30 August 2008 - 08:10 PM
_Yella SLuR_
Posted 30 August 2008 - 08:40 PM
^ What he said. Typically happens when the fuel pump shits itself. Happened to me in the VN. Just grab a new fuel pump and fit it. It's on the end of a Torrie looking fuel pickup/guage stalk.While it's cranking, get someone to belt the bottom of the tank behind the drivers rear wheel.
_hatcher_
Posted 30 August 2008 - 09:06 PM
If you are not getting a "check engine" light coming on when you first turn on the ignition on, this is also proof the ECM has lost power/earth (there are several power feeds and earths going to the ECM)
Second way the pump is powered, is once the engine fires up and the oil pressure gets up, the oil pressure switch provides power (On VN/P motors) This is not happening to yours because of the first way is not happening.
Cheers,
Dave.
#21
_lx-304_
Posted 31 August 2008 - 07:28 AM
#22
Posted 31 August 2008 - 09:13 PM
I can make the pumps run ie bridge the relay n away they go, but then still no pulse, do u think my prob could be from ign to computer?
I didn't get chance to look today! might have a play next weekend no room in the shed atm to play at night! (bring on daylight savings)
Yella it doesnt' have an internal pump runs surge tank etc (its not in a Vn)
Thanks for everyones help!! Keep plodding along! When its done well put it up in members cars
#23
Posted 31 August 2008 - 09:18 PM
#24
_lx-304_
Posted 31 August 2008 - 09:35 PM
#25
Posted 31 August 2008 - 09:47 PM
