Hi people,
I pulled out the windscreen in the torana yesterday and gues what i found... RUST
Here are some pictures.
Im just wondering Can it be fixed?
Jason
RUST
_SL/R SS A9X_
, Feb 26 2006 08:53 AM
4 replies to this topic
#1 _SL/R SS A9X_
Posted 26 February 2006 - 08:53 AM
Posted 26 February 2006 - 10:33 AM
Hi, if your down heres something to make you feel better http://57rustbucket.com/ absolutely brilliant!!!!!
#3 _MYLJ_
Yes, cut out the rusty sections and Mig in some new bits of steel, I've seen much, much, worse rust than that repaired.Im just wondering Can it be fixed?
#4 _1QUICK LJ_
Posted 26 February 2006 - 12:57 PM
dont panic thats bugger all,quite good for a torana really.as mylj said just cut it out and weld sections in,the best way ive found is to make the section first put it over the top then mark around it then cut out marked out section then do a final trim to make a nice fit then weld in i normaly treat with fish oil before and after welding ive done repairs this way and 15 years later not a wisper of rust again. you can buy new panel steel from most salvage yards or steel merchants its pretty cheap for a small sheet you can use anywhere from 0.6 to 1mm sheet up to you.also only use a mig or tig welder. no stick welders?
Edited by 1QUICK LJ, 26 February 2006 - 12:58 PM.
#5 _SL/R SS A9X_
Posted 28 February 2006 - 03:08 PM
Hey today i clean it up most of it was just surface rust
Jason
Jason
