? difference between turbo and trimatic blocks?
9 replies to this topic
#1 _lx_mad_
_lx_mad_
Posted 25 September 2008 - 10:27 PM
hi,
im looking at converting my lx sedan back to an auto (its currently running a toploader)
its 308 block, engine number starts OT?? can anyone tell me how to tell if its a turbo pattern or trimatic pattern.
thanks
also if anyone is interested in the toploader set up let me know.
#2 FastEHHolden
FastEHHolden
    Steptoe
  • 5,114 posts
Posted 25 September 2008 - 10:36 PM
I'll bet it actually says QT if you look really close...and that makes it HQ era...the cast date on the block will give its exact date for you..post the numbers up if you don't know how to read the code..its near the timing cover.
Being a QT makes it an aussie pattern.
Edited by FastEHHolden, 25 September 2008 - 10:37 PM.
#3 _@milco@_
_@milco@_
Posted 25 September 2008 - 10:48 PM
i have two QT blocks that are turbo pattern in the shed, one is standard bore as well.
#4 _lx_mad_
_lx_mad_
Posted 25 September 2008 - 10:51 PM
the number on the block is OT 9944*
I looked super hard at the 'O' and its definitely an O not a 'Q'
#5 rodomo
  • 17,999 posts
Posted 26 September 2008 - 12:55 AM
Maybe look super hard with a magnifying glass? :huh:
#6 ls2lxhatch
  • 5,332 posts
Posted 26 September 2008 - 02:12 AM
This is a 308 out of a WB statesman with the turbo/chev bolt pattern. You can see where the aussie bolt holes are cast but not drilled.
#7 ls2lxhatch
  • 5,332 posts
Posted 26 September 2008 - 02:34 AM
There is a better picture in this thread.
http://www.gmh-toran...showtopic=20244
#8 yel327
  • 13,100 posts
Posted 26 September 2008 - 06:19 AM
Is it QT9944x or QT9944xx ?
The first one is HQ and will definitely be a 4spd block. The second is mid 1978 HZ and could be either 4spd or Chev pattern.
One easy way to tell is by the dowel size. Holden is small, Chev is huge. And you can pick it from the front too.
If it has an OT prefix it's either been decked and you've lost some number depth hence the Q looks like an O or it's been restamped incorrectly. Holden didn't use I or O in the letters on engine numbers or casting dates so it's not a mis-stamp.
#9 _Plucker_
_Plucker_
Posted 26 September 2008 - 10:10 AM
Well done I have learnt something to day and I can go home.............lol
#10 _lx_mad_
_lx_mad_
Posted 26 September 2008 - 04:03 PM
thanks for the info guys.
