Urgent,conecting 100 AMP Alternator
_76S.L.R_
Posted 27 September 2008 - 04:30 PM
Posted 27 September 2008 - 04:42 PM
Posted 27 September 2008 - 05:00 PM
_76S.L.R_
Posted 27 September 2008 - 05:02 PM
Posted 27 September 2008 - 05:06 PM
_76S.L.R_
Posted 27 September 2008 - 05:27 PM
Thing is,D+ is not indicated on the Alternator!? just an opening with the 2 Male Spade Connectors nothing stamped on it,no brand name or anything either so I have no idea which spade I connect the Small wire to??,Do I need to wire up this Sensing wire thingee too?Small wire to D+ and is should work.
_BlownOutlaw_
Posted 27 September 2008 - 05:29 PM
If its like mine, which I just got going, which is an 85A unit I got from Castlemain Auto Elect, its got the black regulator set up on the back with a socket which has 2 terminals, like mini spade terninals. One is labled L the other is S. One is to the light the other is 12V sense I think. The original lead to the light has been connected to L and the S is to go to 12V ignition, ive put mine to the coil + . Seems to work good now that I have gotten the resistor wire out of circuit.
_76S.L.R_
Posted 27 September 2008 - 05:40 PM
Mines an 100 AMP version with internal regulator and from my understanding I thought I just put that main power wire with the eyelet to the same threaded rod part like on my old one then connect that female spade connector wire to one of the spade terminals on the alternator but as its not marked I dont know which one or how to find out which one!? but Im not the brightest spark when it comes to electrics so Im probably wrong assuming this is how its supose to be wired up?.................Gday
Posted 27 September 2008 - 05:47 PM
What other car do you have at home?
_76S.L.R_
Posted 27 September 2008 - 06:14 PM
a Ricer NISSAN 180SX which is my daily driver:308's too thirsty for todays petrol prices.............Oh, that alternator.
_BlownOutlaw_
Posted 27 September 2008 - 06:26 PM
Could be an option, but you would think it would have a label of some sort
_76S.L.R_
Posted 27 September 2008 - 06:32 PM
I had thought of doing that but I havent tried yet because I thought if I put the Spade bit wire on the wrong terminal something might f*ck up?,with these internal 100 amp alternators they allways list them as saying you can hook them up in Single wire fashon or 3 wire? if I hook up my wiring the way it is now to the alternator I'll only be running 2 wires so still unsure if this will cause probs? and the other concern is I dont know if you have to to upgrade the gauge of wiring when going to 100 Amp units?...............Put the spade connector on one of the pins, dont start the engine, but just turn the key to on, and see if the dash light comes on? if not try the other one.
_BlownOutlaw_
Posted 27 September 2008 - 06:39 PM
Posted 27 September 2008 - 06:41 PM
_76S.L.R_
Posted 27 September 2008 - 07:34 PM
just had a look at the nissan one,it has the usual eyelet power wire,another wire/plug at the lower rear then a 2 pin plug(with 2 wires) that plugs in the side of the alternator like the opening/shape on the alternator I bought today.The guy I bought the Chrome Alternator off is selling them from home for,no markings on the box or alternator? he says they are manufactured by the same mob that makes the MSD ones:nice chap too we spoke cars for agesDoes the alt. on your Nissan have a similar plug? Is the Nissan a Bosch alt?
Posted 27 September 2008 - 08:24 PM
http://holdenpaedia.....php/Alternator
_76S.L.R_
Posted 28 September 2008 - 10:53 AM
Posted 28 September 2008 - 11:26 AM
Why are you changing your alternator in the first place?
If your dashlight globe is blown, your old alternator wouldn't have worked either.
_BlownOutlaw_
I was told the other terminal labled S was to go to a +12V ignition source, as you dont want 12V into it all the time from the battery, so I was told to make a lead up between + terminal of the coil and the S of the alt. The alt only charges when the engine is running, hence the 12V from coil.
Worked OK this way.
The lights dont necessarily turn off when the motor is running, they turn off when the alternator is providing power. Hence you can have a faulty alternator and the warning light will come on even if the engine is running.
_76S.L.R_
Posted 28 September 2008 - 11:42 AM
Because before I pulled the old alternator out that light worked,mind you a few days ago I was fiddling behind the dash(fitting LED's in the dash)either ive distrurbed some wiring,blown a bulb? or ive just conected the dash warning light wrong.I was fitting the 100 AMP Alternator because my batterys keep going flat?,im running Twin AU FANS and just fitted H4 Lights so bought the 100 AMP Alternator to try help the problem.Thats interesting.
Anyone know what size wires I should be running in using this 100 AMP Alternator?,the other problem still remains too:I dont know which spade terminal is which on the Alternator?(why its not marked I'll never know?)...............
#21
Posted 28 September 2008 - 12:07 PM
The S (Sense wire) connects to the Alternator's B terminal or the Battery's positive terminal. The other terminal connects to the Indicator light.
#22
_76S.L.R_
Posted 28 September 2008 - 02:27 PM
#23
_76S.L.R_
Posted 29 September 2008 - 04:54 PM
#24
Posted 29 September 2008 - 08:52 PM
*like the sense wire that makes no sense lol*
#25
_The Baron_
Posted 29 September 2008 - 09:58 PM
As there is no load on the sense wire, there will be no (minuet) volt drop under load.
I believe this information is used by the alternator smarts to regulate the voltage applied to the battery for charging purposes. My alternator (Bosch 85 amp) also boosts the exitation field at low rpm (idle) to maintain the charge/voltage produced.
Works great.
PS mine has a special plug to make these two small connections. They appear as very small male spade connection on the alternator but should have the special plug.
I have a connection diagram if needed, pm me and I can fax/email if needed.
