building motor for nitrous
#1 _Bomber Watson_
Posted 27 February 2006 - 10:14 PM
i already have moderate strenghening of the bottom end, acl race series pisonts, arp rod bolts, blue rods, blue crank, all balanced, ect.
i have head of running a couple of extra thou?? if so how many? and also i have heard of titanium rings being the hot setup???
also the fuel system, i'll be running 3/8" lines for the carbs (su's) and i'll feed the nos from the origional 5/16th line, will this be arright?? i ws thinking about running a swirl pot with a small pump feeding it, and another small pump feeding the nitrous line...say holley reds maybie???
anything else i need to know?? the motor will be tuned on an engine dyno before it goes in the car.
cheers, any advice is good advice.
Posted 27 February 2006 - 10:58 PM
Posted 27 February 2006 - 11:44 PM
Also, I understand you need to retard the timing a bit when running it too. You could go all out and but a fancy ignition system that has this ability (flick a switch from your dash and bam, nitrous curve ready to go, easy as)....
#4 _kaz from adelaide_
Posted 28 February 2006 - 10:29 AM
Posted 28 February 2006 - 11:57 AM
Naa i heard you gotta use less ignition timing
DAmo
#6 _QIKSLR_
Posted 28 February 2006 - 02:20 PM
I'm gonna go the MSD Digital 6 ignition. It's got a retard circuit so you can wire it up so that when you hit the nitrous it retards the timing while your injecting it then puts it back. That way you don't lose performance from having to reduce your static timing. It's also got a soft touch rev limiter which is the type you need for nitrous, not the type that keeps cutting off the first cylinder(s) only.
If your gonna run a decent shot which I assume your are if your going a wet shot, you want forged pistons and you want a nitrous spec cam, which I think is the same as a blower cam. These have a longer duration which is what you want for nitrous.
Also look at a few safely options. I'm still undecided on what to do. A few things in mind are a low fuel pressure cut-off to avoid injecting nitrous when its lean, the old switch on the throttle so you can only inject when your flat to the boards.
#7 _high_rpm_
Posted 28 February 2006 - 03:50 PM
#8 _Torana482HP_
Posted 28 February 2006 - 04:54 PM
but as i read on another post your waiting to blow the engine anyway to make way for a 253 so i wouldnt worry about the pistons too much
Posted 28 February 2006 - 07:07 PM
What are you referring to here ?
I have never heard of titanium rings...........
The best advice I can give you is to find someone who runs a Holden 6 on N2O SUCCESSFULLY and become their friend, get all your advice from one source, and don't be too greedy.
#10 _Bomber Watson_
Posted 28 February 2006 - 08:49 PM
and titanium rings are something i was told about, i have never head of htem eather but i thought i might ask.
yes i do want to build an 8 for it but not to damb soon. six owes me a lot of gold and it's still in bits. the pistons i have atm are hypers, real snazzy lookin pistons though. but yeah, recon they will melt??
the head studs i will do, thats no dramas.
nos spec cam, i'll look into it.
i'll probably only be looking at 100-150hp shot, nothing to wild really.
sparkler injection....i nearly pissed myself at that one.
#11 _draglc_
Posted 28 February 2006 - 09:13 PM
my 202 is built for nitrous. 202 + 40thou, flat top pistons, blue rods, nitrous cam .238 & .248 @ .50, 1.6 inlet & 1.5 outlet ratio roller rockers (to allow for the shorter duration on the inlet for the nos), 186 YT head big valves etc, straight cut gears, triple 1.75 HIF SU's with 3 foggers. approx 100 shot over the 3 runners.
mine arent forged, but if its set up properly it shouldnt be a problem. wont be running nos all the time anyway. i do want to get the msd 6A+ (digital) as it will make retarding the timing so much easier.
A1
#12 _Bomber Watson_
Posted 28 February 2006 - 09:18 PM
so yeah, atm it sounds like i just keep going the way i was, look at a diferent cam and see where it goes...
cheers and more info welcome.
#13 _Loki_
Posted 01 March 2006 - 03:51 PM
I can't imagine a stock 308 surviving this kind of punishment, was I not right in saying that?
Something that, as far as I'm aware, in QLD, you cannot have the lines for Nitrous even installed in your car whilst on the street, even if you don't have a bottle in the car let alone connected.
Hefty fine if caught i believe.
#14 _Bomber Watson_
Posted 01 March 2006 - 07:04 PM
and i have been told that you can add up to half of your motors hp output safley??? if this was true 100 on a 308 would be ok i suppose...
#15 _82911_
Posted 01 March 2006 - 11:45 PM
Strongly suggest you buy "Nitrous oxide injection" a book by David Vizard.
Whilst it is not current tech, it will set you straight with some of the more popular N2O myths that are around!!!
Untill then... do nothing... you will more than likely blow yourself up.............
again!!!
Cheers Greg..
#16 _[BOTTLEDUP]_
Posted 02 March 2006 - 02:04 AM
Then and only then once you have an understanding of exactly how a nitrous system works, and how critical things like bottle pressure, fuel pressure, solenoid location plumbing etc are would I suggest you undertake it.
Anyone who thinks you can just bang a kit on there and away you go is a fool.
Generally speaking the rule of thumb is approx 50% of you N/A power can be added in nitrous, any more than this and you enter the danger area, best left to the experts in the field. A nitrous backfire will quickly ruin your day.
#17 _Bomber Watson_
Posted 02 March 2006 - 06:12 PM
and i won't be bgucking with it to shortly, gotta build the motor first...
might stick it on the wipper snipper though for something to do
Posted 03 March 2006 - 08:42 AM
Also another book I have is this one.... http://www.amazon.co...5Fencoding=UTF8
and its not bad either. Remember those prices are $US but it still works out cheaper than buying locally.
I seem to remember Greg (82911) running a fair whack of N2O in days gone by.... as did I, but neither on a Red 6. A local here runs high tens in an HB with a fairly standard 202 and 350 holley with a plate. He has had a few melt downs over the years though !
#19 _Bomber Watson_
Posted 03 March 2006 - 07:56 PM
#20 _user asked to be removed_
Posted 04 March 2006 - 08:57 AM
*Liam
#21 _Bomber Watson_
Posted 04 March 2006 - 12:34 PM
nitrous is removeable, and most of it can be taken from car to car.
#22 _LJ308injected_
Posted 07 March 2006 - 11:26 AM
Cheers: Steve
#23 _Bomber Watson_
Posted 07 March 2006 - 05:52 PM
yes i'm hearing a lot of this forgies for nos chat, i'm thinking about getting forged slugs for her.
the kit i have only goes down to 100hp i think, i'l have to look further into it. it's an endelbrock performer rpm kit with six nos brand fogger2 foggers....
#24 _Bomber Watson_
Posted 08 March 2006 - 08:30 PM
#25 _@milco@_
Posted 08 March 2006 - 10:18 PM
nah i would do that, you have them already and you dont want to get forgies and get the block redone,allright, this is gonna sound dumb, but what is the worst thing that can happen with the hypers??? Melt a couple?? seeing though the block is already bored to suit the hypers i have i'm considering dropping them in untill they start giving trouble then rebuild the motor +40 with forgies....does this sound stupid?
just wack it to gether and start off small then work up
