My SS is leaking fuel from the gauge unit on the tank, is it just a seal? do I have to drain and remove the tank to get it out? in the book it says you need a special tool to get the unit out, do you?
Thanks if you can help out.
Fuel Leak
to fly
, Feb 28 2006 04:43 PM
2 replies to this topic
Posted 28 February 2006 - 04:43 PM
#2 _Herne_
Posted 28 February 2006 - 05:05 PM
It is just a seal, I took a perished one along to Rare Spares and they found a replacement that did fit with no problems.
If one has the right tool it would be nice, but to remove mine I used a couple of screwdrivers ever so carefully. It's a bayonet fit.
Umm don't try it with a full tank lol but it is rather high from memory.
Herne
Herne
Posted 28 February 2006 - 06:54 PM
yeah its just an o-ring type seal, and yes drain the tank first and also buy some fuel line to replace the rubber bits as they do perish a bit with age and its a lot easier to do the lot while you are under it.
