price of headgasket?
#1 _hrt1and2_
Posted 01 March 2006 - 12:13 PM
thanks
Posted 01 March 2006 - 02:12 PM
Posted 01 March 2006 - 02:30 PM
#4 _Sammy_
Posted 01 March 2006 - 02:36 PM
#5 _lx5008_
Posted 01 March 2006 - 02:56 PM
#6 _Loki_
Posted 01 March 2006 - 03:37 PM
Would this question seriously have not been answered easier by going to a store and asking?
Head Gaskets for my 308 cost about $35ish+ each.
Edited by Loki, 01 March 2006 - 03:37 PM.
Posted 01 March 2006 - 03:43 PM
#8 _Yella SLuR_
Posted 01 March 2006 - 05:25 PM
Posted 01 March 2006 - 05:37 PM
Posted 01 March 2006 - 06:26 PM
I have a billion bits of leftover VRS sets...If I needed anything it would be a head gasket.
Posted 01 March 2006 - 08:07 PM
Posted 01 March 2006 - 08:09 PM
being a member of SAUNA you should have known that straight away....maybe a case of too many TLA's (three letter abbreviations)..I'm in the Army..we use them for everything.
Edited by FastEHHolden, 01 March 2006 - 08:12 PM.
Posted 01 March 2006 - 08:14 PM
regards.
#14 _hrt1and2_
Posted 01 March 2006 - 09:41 PM
Posted 01 March 2006 - 10:38 PM
Posted 01 March 2006 - 10:40 PM
#17 _hrt1and2_
Posted 02 March 2006 - 12:05 AM
cheers.
Aaron.
Posted 02 March 2006 - 10:28 AM
#19 _hrt1and2_
Posted 03 March 2006 - 12:25 AM
buy a new set of welsh plugs...chuck them in the freezer...get a pin punch...tap one side of the welsh plug, it will turn sideways, grab a set of multi grips and pull it out of the hole...inspect the hole and use a bit of wet and dry to clean the hole....grab your very cold welsh plug and a socket that fits neatly inside it (not too small) and tap it in the hole....you can use a sealant on them if you must but I only do that if the old one was leaking or the hole looked rough.
u make it sound all too easy
Posted 03 March 2006 - 07:55 AM
#21 _Loki_
Posted 03 March 2006 - 11:17 AM
I was paranoid about tapping the welsh plug into the block at first as wellbuy a new set of welsh plugs...chuck them in the freezer...get a pin punch...tap one side of the welsh plug, it will turn sideways, grab a set of multi grips and pull it out of the hole...inspect the hole and use a bit of wet and dry to clean the hole....grab your very cold welsh plug and a socket that fits neatly inside it (not too small) and tap it in the hole....you can use a sealant on them if you must but I only do that if the old one was leaking or the hole looked rough.
If you tap it from one side it won't happen though
Goodluck
#22 _Herne_
Posted 03 March 2006 - 11:23 AM
Is it to shrink them down a tad?
I thought the idea was for them to expand when tapped in using a socket bit.
I have not heard of this before but then again I haven't been around when a mechanic puts them in, I have put some in with mates but that doesn't make it right albeit they didnt leak
Herne
Edited by Herne, 03 March 2006 - 11:25 AM.
#23 _user asked to be removed_
Posted 04 March 2006 - 08:15 AM
