hooking up electric fuel pump
Posted 01 March 2006 - 05:20 PM
Posted 01 March 2006 - 06:30 PM
#3 _rorym_
Posted 01 March 2006 - 06:48 PM
Edited by rorym, 01 March 2006 - 06:49 PM.
#4 _purpleLC_
Posted 01 March 2006 - 09:55 PM
it bleeds off excess pressure to the fuel tank even
after you have switched the engine off.
This helps with starting a hot (temperature wise) engine.
Louie
#5 _Torana482HP_
Posted 01 March 2006 - 10:12 PM
rory i think if you want a return line you need a bypass regulator, dont think it will work with a normal reg, do you know what type of reg u have? and where did you mount your pump exactly?
Posted 02 March 2006 - 06:32 AM
A reg should only be required if you want max efficiency from the fuel system, with the Holley blue it comes with a reg as the psi is adjustable, so install the reg, set it to 7psi and your done. Or buy a Holley red and its preset at 7psi.
Dont forget your ear muffs, there noisy suckers.
#7 _devilsadvocate_
Posted 02 March 2006 - 06:42 AM
hope you mean into the dizzy(or -ve of coil) with a 'tach' relay as wellas getting the power feed from the alternator terminal?Can I ask a question here too? I had the Holley Blue wired today..They did it properly into the alternator with relay etc etc... Do I need to run a return line on the regulator or just blank off the second outlet? Red 308 with STD Rochie in the LC.
Edited by devilsadvocate, 02 March 2006 - 06:45 AM.
#8 _rorym_
Posted 02 March 2006 - 07:34 AM
I dont want a return line unless it is neccessary. The pump is mounted in the boot 3 inches from the tank feed, the reg is the std one that comes in the Holley Blue box.1 inlet, 2 outlets.
#9 _devilsadvocate_
Posted 02 March 2006 - 08:38 AM
#10 _rorym_
Posted 02 March 2006 - 01:16 PM
#11 _Torana482HP_
Posted 02 March 2006 - 05:07 PM
#12 _rorym_
Posted 02 March 2006 - 05:23 PM
