LXCHEV's new custom pipes *PICS*
Posted 03 March 2006 - 12:05 AM
FYI: The extractors are 1-3/4" prim into 2" sec into 2-1/2" collectors.
I call this first pic the "Jigsaw Puzzle Mess". Everything was built with flanges and slip-joints, to allow for easy fitment & removal with the engine and everthing else still bolted in place....
These next 3 pics show the passenger side pipes:
Here's a shot to show everyone that the HPC coating is done on the inside as well:
Driver's side pipes:
Quick shot of my 3 inch dumpers! These will bolt up after the mufflers and dump just before the diff (eg. for car events, drags etc). For general cruising, they will be bolted off so I can put my tailpipes back on instead.
And here we have the finished product:
This last shot shows I could also bolt the dumpers on after the extractors if running open pipes (now that would sound sweet!):
Cheers,
Brett.
#2 _Flamenco_
Posted 03 March 2006 - 12:31 AM
Posted 03 March 2006 - 04:53 AM
#4 _ChiaLX_
Posted 03 March 2006 - 05:50 AM
You have stalled my project again! lol
After looking at the finish on those pipes I am just gonna have to take mine off and get them done. I was loosely contenplating it, but wow! they really look great and i may as well do it before i get it on the road or it will never happen.
Cheers Brett and put more pics up when they're fitted.
#5 _MAWLER_
Posted 03 March 2006 - 07:46 AM
Peace,
Edited by Liam, 03 March 2006 - 07:47 AM.
Posted 03 March 2006 - 10:02 AM
knoath - If I make it to the Heathcote drag day, I will probably try a couple of passes with open pipes, why not! We gotta make lots of noise there right! But my car normally seems to run better with my system fitted, feels a lot sharper. But we'll see what happens both ways...
ChiaLX - hahaha sorry mate. But you won't regret it!
Liam - yep I had all the bolts and captive nuts done. It was only an extra $1 or $2 per bolt so I thought do it for sure. Looking back, I should have also sent them my header bolts, didn't even think about them, d'oh!
#7 _draglc_
Posted 03 March 2006 - 11:59 AM
A1
#8 _Perth Brake Parts_
Posted 03 March 2006 - 12:00 PM
Who made the pipes for you ?
I think I need some slightly bigger primaries than the Tri-Y's I have
1 3/4 has been recommended
#9 _LX406_
Posted 03 March 2006 - 12:59 PM
#10 _Herne_
Posted 03 March 2006 - 01:21 PM
Herne
Posted 03 March 2006 - 02:48 PM
You cant win, make em 1 piece and there a shit fight to work around, get in and out. Make them multipiece and there a breeze to work around and remove but they will leak.
Gotta love that HPC, looks great before you install them, then its tears when you scratch them getting them in the car.
Posted 03 March 2006 - 02:51 PM
If your making a good 450HP and over 400Ft/lbs of TQ go the 1 3/4", if not stick with 1 5/8" what you dont make up for in HP you will gain in low down TQ.Sexy
Besides the 1 5/8" give you that little extra room, less chance of pipes fouling.
If you want to gain extra HP, dont go the 1 3/4" primary, enlarge the collector to 3". You will gain more from the collector to the tips by going larger then by increasing primary size and running smaller collectors.
#13 _Herne_
Posted 03 March 2006 - 03:11 PM
It's nice to be able to spend the big bucks and finish the job off professionally.
As stated above hope you don't have trouble with future exhaust leaks but seeing as they are easy to remove (something else I didn't realise) I guess any leaks can be easily fixed.
Herne
Posted 03 March 2006 - 09:16 PM
I have jet hot tri-y's which I think are 1 5/8"If your making a good 450HP and over 400Ft/lbs of TQ go the 1 3/4", if not stick with 1 5/8" what you dont make up for in HP you will gain in low down TQ.Sexy
I have plugged some #'s into the desktop dyno and my expected theoretical HP is under 450 (just)
So I might stick with what I have I guess and chop off the small collectors and fit larger ones as you say.
Its a streeter not a track car so the torque is more important to me.
PBP is my work alter ego..... hence this post from me.
#15 _1QUICK LJ_
Posted 04 March 2006 - 12:47 PM
ps. with the dyno program its too generous with power on lobe separation always go 2 degrees tighter than the program recommends eg:if 112 is best go 110,
also you have to correct the power if using a dual plane manifold take off 30 horsepower if using a single plane manifold take off 50 horsepower,this will be your real world power figures.
beleive me ive done alot of testing with these programs we have backed up our testing with dyno tests and flow tests on quite a few engines, if you want to know anything more about the programs pm me. sorry for the highjack
#16 _1QUICK LJ_
Posted 04 March 2006 - 12:49 PM
Posted 05 March 2006 - 10:02 PM
Also - just to comment - my very first set of of Tri-y's were also 1-5/8" primaries and only 2" collectors. The car still went awesome, made heaps of power & torque, and still ran 11.99 down the quarter. Just goes to show what can be achieved.
draglc - I like your idea of hanging them on the wall. Imagine sitting in the lounge-room and looking up to them! Now that's what I call serenity! hahaha
LX406 - As tempting as it is mate, I don't think I'm going to put the fresh donk on the engine dyno after all. Cash is real tight again now (credit card is beginning to warm up my pocket, don't really want to get it glowing red). And my engine guy said he wouldn't bother for this type of engine. Also, I'm pushing hard to make the forum drag day, so every single day counts now, I just don't have the time! It would be nice to get the Hp/Torque figures though, but if I did, I would want my extractors bolted on and not another set, so it kinda brings me back full circle anyway (with regard to not killing off the HPC coating)...... Who knows what I'll end up doing!!!!
As for exhaust leaks - hopefully that never becomes an issue. Only time will tell. I will be assembling the slip joints with the high-temp red exhaust goo.
#18 _ultrabluea9x_
Posted 06 March 2006 - 01:23 AM
dynoed yet?
whats the results?
Posted 06 March 2006 - 01:36 AM
