Rotisserie
_Bruce Burnout_
Posted 11 November 2008 - 11:47 AM
_lx-304_
Posted 11 November 2008 - 12:04 PM
dave
Posted 11 November 2008 - 12:30 PM
_304Lx_
Posted 11 November 2008 - 05:54 PM
Posted 11 November 2008 - 05:55 PM
Ruts.
_Viper_
Posted 12 November 2008 - 04:01 PM
Posted 13 November 2008 - 08:31 PM
To make an easy head unit what you do is go to your local wreckers and cut the rear axle tubes and brakes off a front front wheel drive magna sedan. Get yourself two rims and two handbrake handles. As can be seen int he pictures the unit spins on the axle ends. When I get the car in the position I want I just pull the handbrakes on at either end. The car in the picture spins 360 degrees and I can hold it on any angle I want. As you can also see the head units are in line with the bar brackets but I have set the brackets off set, don't ask me why it just happened like that and I fluked the C of G. Hope this helps and feel free to ask any questions. By the way from the floor to the centre of the axle tube is 1400mm (with the wheels attched)
Ruts
_studricho_
Posted 15 November 2008 - 07:45 AM
_Barman_
Posted 16 November 2008 - 09:20 AM
and i hung the front from engine lifting frame, then i put a 205litre drum and a chassis stand under it, all very cheap and worked very well.
_Yella SLuR_
Posted 13 January 2009 - 08:55 PM
Rotisserie is coming along nicely. Using a flywheel, and the drive gear out of a starter motor, which is giving me 15:1 ratio, with the starter motor gear on a hand wound handle (fits very neatly on 12mm solid bar). The advantage of this is that I can hook up a starter motor and battery to it at car shows, and the car can do 360's all day, without any damage to the tyres.
Looking interesting. Just have to weld together the stand for the other end in the morning.
Today was spent adding 200mm to the pick-up points, and the other half setting up the flywheel/stater motor gear setup. Pics tomorrow on my variation on the theme.
Edited by Yella SLuR, 13 January 2009 - 08:56 PM.
_LX-5000_
Posted 13 January 2009 - 09:38 PM
_LX-5000_
Posted 13 January 2009 - 09:42 PM
towbars on toranas can be useful!!!!
Edited by LX-5000, 13 January 2009 - 09:44 PM.
_Yella SLuR_
Posted 14 January 2009 - 01:38 PM
^ No wheels, cause sloped floor, so it won't be going nowhere.
^ detail of the flywheel & starter motor throw-out gear.
_torana_umunga74_
Posted 14 January 2009 - 03:38 PM
_@milco@_
Posted 14 January 2009 - 05:57 PM
_Yella SLuR_
Posted 14 January 2009 - 07:13 PM
_torana_umunga74_
Posted 14 January 2009 - 08:35 PM
id get somethin under it incase.. thing is steel can fatigue even under paint and you wont notice, say u take it off again to tweak it it might not hold again. i would cut that vertical bit out and but a bigger thicker piece in, everthing else would be ok.See how we go, a boxed SHS is the most efficient section. It is a bare shell, I'll see how it goes and report back. We'll see how we go and see if it needs strengthening or not.
_Yella SLuR_
Posted 14 January 2009 - 11:49 PM
I like the minimalist approach.
Edited by Yella SLuR, 14 January 2009 - 11:52 PM.
Posted 15 January 2009 - 08:16 AM
whack in a heavier vertical post (I'm assuming that is the one peeps think isn't beefy enough)
_Yella SLuR_
Posted 15 January 2009 - 08:32 PM
Thanks for the heads-up/feedback.
#21
_torana_umunga74_
Posted 15 January 2009 - 09:28 PM
goodluck mate!
#22
_Yella SLuR_
Posted 15 January 2009 - 11:41 PM
All the nuts are removed on the front end, so it's just a matter of punch out the bolts, jack it up (yup, the jack reaches the magic point) and she should be good. Brackets are mounted already, so she should be all good to go. Did a dry run of how I'm going to do it tonight, but will wait till morning and daylight just in case need to do some quick fixes.
EDIT: Wasn't interested in doing it a third time, so I settled on 75 x 75, then just asked them for the thickest wall size, which was 3mm. Prolly a bit of overkill, but easier than doing it again, or being squashed.
Edited by Yella SLuR, 15 January 2009 - 11:47 PM.
#23
_Yella SLuR_
Posted 16 January 2009 - 11:11 AM
Car rotates fully within 1.8m x 1.8m space, with 50mm from the body to the support leg at the closest. So answering my question, optimal rotisserie for Torries is 950mm posts, with 200mm offset (allows you to use the jack to get it onto the rotisserie).
Thanks again guys, works a treat, including the handle.
#24
_Herne_
Posted 16 January 2009 - 11:23 AM
Nice bit of engineering.
Herne
#25
_Yella SLuR_
Posted 16 January 2009 - 11:33 AM
