help!! My bonnet wont fit!!
#1 _jdss57_
Posted 03 March 2006 - 04:49 PM
Posted 03 March 2006 - 04:55 PM
lol, try and get in contact with 'EFI-57L'; he hasn't cut the bonnet and he's got an identical setup. It's a clean LH in Devil Red from memory, with big five spokers on there. Someone on here is bound to know him...
#3 _torana_
Posted 03 March 2006 - 05:04 PM
#4 _jdss57_
Posted 03 March 2006 - 05:07 PM
#5 _jdss57_
Posted 03 March 2006 - 05:09 PM
#6 _high_rpm_
Posted 03 March 2006 - 05:25 PM
might as well not have a bonnetthen i might have to cut the bonnet slightly
#7 _jdss57_
Posted 03 March 2006 - 08:57 PM
what do you's think? is the motor laying back too far.. i have already had to modify the tunnel.. dont think the box can come up any higher..
#8 _Bomber Watson_
Posted 03 March 2006 - 09:00 PM
#9 _jdss57_
Posted 03 March 2006 - 09:02 PM
#10 _Jewboy_
Posted 03 March 2006 - 09:51 PM
#11 _jap-xu1_
Posted 03 March 2006 - 09:59 PM
tailshaft woes :(
drop the engine mounts and lift the box mounts if possible
#12 _jdss57_
Posted 03 March 2006 - 10:08 PM
i did try the bonnet and it touched on the covers. i've got a bit more movement at the g/box now but so i'll wait till tomorrow and get a mate to help put the bonnet back on and see how we go..
#13 _ChiaLX_
Posted 03 March 2006 - 10:46 PM
I think the box or box mount is your problem. As far as i know the injected block and aspirated blocks are similar so should sit the same (angle wise) that is.
I think someone has actually mentioned on this forum that you have to re-work the tunnel (nice way of saying cutting and shutting) on a totana to fit a turbo 700 box in as they are very wide and dont fit right.
I am sure someone has done this and can steer you in the right direction. I think the problem is with the box. Good luck.
#14 _Yella SLuR_
Posted 04 March 2006 - 04:49 AM
Have you tried sitting the bonnet on, as it curves up in the middle, i.e. can't judge by running a string line across the bay.
#15 _user asked to be removed_
Posted 07 March 2006 - 09:32 PM
*Liam
#16 _tj81_
Posted 08 March 2006 - 10:22 AM
Sounds like something Rod Hadfield would say !Either cut a hole through the bonnet, make the engine mounts lower, or smack the bonnet with a hammer!
*Liam
My 2c, Try the torana engine mounts first.
If that dont work, issue is definately related to the tranny.
#17 _brett_32i_
Posted 10 March 2006 - 11:57 AM
How true is that statement !!!Sounds like something Rod Hadfield would say !Either cut a hole through the bonnet, make the engine mounts lower, or smack the bonnet with a hammer!
*Liam
that man is definately a hotrodder....
#18 _jdss57_
Posted 10 March 2006 - 06:13 PM
Posted 10 March 2006 - 06:18 PM
i think i was stupider after listenin to them..
AAHaaaaHaHaaaaHaaa.
Same here - every time.
#20 _keith1962_
Posted 10 March 2006 - 06:27 PM
HQ mounts are the way to go but i think u will find 1 of the mounts are lower not sure which side but you need to aquire 2 x smaller of the 2 mounts.
As for the box its sitting down too low which is forcing the front of the motor up.
cheers Keith
