my mate is converting the rear of his HZ kingswood to WB disc, and I was just wondering where the residual pressure valve is and how to remove it
makka
, Nov 20 2005 10:53 AM
5 replies to this topic
Posted 20 November 2005 - 10:53 AM
#2 _CHOPPER_
Posted 20 November 2005 - 01:04 PM
Remove the line from the M/C to the rear brakes, it's in there. Apparently it's a brass olive and needs to be carefully removed using a self tapping screw. Screw it into the olive and once it bites, it should be able to be pulled out. Excuse the vauge description.
#3 _luv the uc_
Posted 20 November 2005 - 03:22 PM
Remove the brass olive as chopper said, the valve is behind this. Once removed replace the olive and refit the brake line.
#4 _redlh_
Posted 20 November 2005 - 03:44 PM
I'm curious, can you buy replacement brass olives? When I did mine, I damaged the seating face of the olive and it's been weeping ever since. <_<
Posted 20 November 2005 - 08:46 PM
No you can't buy olives
Only way to get them in in a major kit from PBR
If your handy with a lathe you can spin them up and reface the seat
Posted 21 November 2005 - 11:09 AM
so its behind where the rear brake line screws into the m/cyl?
sounds easy enough to do
