LJ steering for V8 conversion
#1 _PRO400_
Posted 16 November 2008 - 06:49 PM
Posted 16 November 2008 - 07:56 PM
the cutting of shaft and machining of the cotter pin grooves must be done cold milled in SA regs
I could measure mine if you need the lengths
#3 _panthervs_
Posted 16 November 2008 - 08:02 PM
#4 _PRO400_
Posted 16 November 2008 - 08:07 PM
#5 _rorym_
Posted 19 November 2008 - 06:58 PM
http://www.gmh-toran.......ticle&id=19
Edited by rorym, 19 November 2008 - 07:02 PM.
Posted 19 November 2008 - 07:06 PM
also is there a difference in the column length for 4spd and 3 on the tree as there is a gear linkage hanging out the bottom of the 3spd column
Posted 08 December 2008 - 09:29 PM
#8 _rorym_
Posted 08 December 2008 - 11:01 PM
Edited by rorym, 08 December 2008 - 11:02 PM.
Posted 09 December 2008 - 01:27 PM
Posted 09 December 2008 - 01:48 PM
so if 3 knuckles are used, wouldn't you need a support between 2 of them?
Correct. CRS sell a kit or you can make your own by passing the middle shaft thru a pair of 9/16" ID rod ends secured to the crossmember.
By the way the 4cyl steering column is a lot LONGER on the engine bay side than a 6 cyl unit.
Posted 10 December 2008 - 10:00 PM
Adam
Posted 10 December 2008 - 10:26 PM
Adam , how is the gen3 conversion going? I found a sump but it's going to cost alot money @ 65cent Aus. How much room to you from block to k frame?
Posted 13 December 2008 - 03:14 PM
Yeh its slow at the moment had to store it at a mates place for awhile...How ever im using the Moroso 20140 sump and it sits a little too low and too far forward (mounts) But with a few mods to my mounts ill get it in the right place...From memory ive got to move the motor 2 inches back and touch higher just to be safe.
Adam
#14 _XU1-043_
Posted 05 February 2009 - 04:35 PM
#15 _rorym_
Posted 05 February 2009 - 07:15 PM
#16 _gtr161s_
Posted 13 March 2009 - 07:49 PM
#17 _rorym_
Posted 13 March 2009 - 09:53 PM
