Hi all,
I am i the process of putting security door locks & a new drivers side mirror on the LJ but cannot remove the window winder on the front driver & front passenger side , the door handles come off fine as they were "loose" but the window winders are hard up against the door trim & I cannot get to the pin holding them (i assume it has the same style split pin holding it as the door handle??).
Does anyone have a simple or not so simple soltion to my problem??? Any help appriciated guys & girls.
Cheers,
Mick
LJ Door Trims
LOWS2
, Mar 04 2006 05:18 PM
7 replies to this topic
Posted 04 March 2006 - 05:18 PM
#2 _Bomber Watson_
Posted 04 March 2006 - 07:28 PM
window winder for some stupid reason has a spring under it from teh facory, to hold the trim out against it. only way to get it easily is with a proper door trim tool. can be done with a screw driver. also, you should be able to push it in, as it's only a heavy spring under the trim.
i didn't bother putting the spring back in my car, havn't had a drama.
#3 _Flamenco_
Posted 04 March 2006 - 09:59 PM
Rag also works sometimes - usually the clip (which is shaped like a 'C') releases by pushing the ends of it away from the winder knob - it can be installed either way. Have a look at it first by pushing the coil spring hard against the door frame.
The proper tool is available at kmart or repco for about $8.00.
Posted 04 March 2006 - 11:39 PM
I use an old choke cable (spring steel) with a hook bent on the end.
Push back the nylon wear pad and "hook" the loop in the clip and pull.
Watch closely where it flys!
RACV MAN
RACV MAN
Posted 05 March 2006 - 10:28 AM
A little off topic but has any tried a fix for loose handle syndrome?(liquid metal maybe)
Posted 05 March 2006 - 10:57 AM
Cheers guys, I will give it a go with the screw driver & if all else fails I will swear at it & go buy the door trim tool from Kmart.
Mick
Mick
#7 _LJ_MAD_
Posted 05 March 2006 - 01:11 PM
I use a hacksaw blade broken in half , alot flater than a screwdriver.
Also a rag can work well.
#8 _Bomber Watson_
Posted 05 March 2006 - 01:38 PM
howabout grub screwing it??? eather the tricky way, put grub screws in the sides of where the shaft bit goes in, will be a prick to do up, or a grubbie striat through the middle from the outside, this will preload the handle on the shaft....A little off topic but has any tried a fix for loose handle syndrome?(liquid metal maybe)
