Well if the breather is too small it can cause problems, but the question is could anything bad come from having a breather line thats too big?
My fuel cell came with 2x -8 (1/2") outlets and the breather line is also -8. So based off that I'd assume that the breather should be half the size of the outlet. I'm only running one outlet so the -8 breather may be overkill, but who cares?
Should there be any some type of filter on the breather line? On a factory setup it runs into the carbon canister but, mine is just bulk headed through the floor.
Fuel tank breather
, Jan 04 2009 12:08 PM
27 replies to this topic
#26
_UDLOSE_
Posted 07 January 2009 - 07:47 PM
#27
_PRO-192_
Posted 07 January 2009 - 08:33 PM
the short answer is no... nothing bad, the two would be for a blown alcohol scenario as they would make 1 cell to suit all and you use what is appropriate... yes a filter is a good idea to stop debris entering the tank via breather as is a 1 way valve.
hope this helps
micko
hope this helps
micko
#28
_UDLOSE_
Posted 10 January 2009 - 07:09 PM
hope this helps
micko
I've got a rollover valve built into the cell, but that won't stop any bugs etc going in right? What sort of filter would u recommend? I've got a -8 fitting sticking out the floor, is there anything that will fit straight onto that?
