what rotors and calipers for a lc308
lakeside
, Nov 20 2005 08:56 PM
9 replies to this topic
Posted 20 November 2005 - 08:56 PM
what rotors and calipers can be used on a lc 308 with standard 13inch steel rims
Posted 20 November 2005 - 09:10 PM
DBA004 and standard caliper with spacers
DBA375 with Volvo 4 pots ( you make them fit....... check out some Group NC racers for how its done)
Posted 27 November 2005 - 07:47 AM
Volvo 4 pots which ones? Arn't there a few different types
#4 _CHOPPER_
Posted 27 November 2005 - 12:08 PM
240 series and 260 series ( mid 70's ) are the common ones from memory.
#5 _lcgtr_
Posted 28 November 2005 - 02:39 AM
what do the guys do with the 2 sets of lines coming out of the caliper
Posted 28 November 2005 - 09:46 PM
Girling caliper to suit vented disc is the preffered one
As for the 2 sets of lines you do this
Remove pistons. Cross drill piston bore between holes to allow fluid transfer to all pistons
Blank off extra non required inlet port (the upper one)
I have some pics of this
Now bear in mind...... the bolt pattern for Volvo calipers is not identical to Holden stubs so the bolt holes need to be plugged and redrilled in the right spot.
The rotor also needs to be reduced in diameter to 256mm from 272mm to allow the caliper to fit
I'm sure there are better ways
#7 _rorym_
Posted 09 December 2005 - 07:09 PM
My stock XU1 brakes work fine, you are only adding 22 lbs, though the time to get to top speed shortens! Any thing above that are reserved for circuit racers and you are really getting into big $ with 4 spot AP or Girling set up. The stockers are fine for street work as Neil says.
Edited by rorym, 09 December 2005 - 07:12 PM.
#8 _rorym_
Posted 09 December 2005 - 07:17 PM
I fitted braided lines and Ultimate pads but will upgrade to DB2500 just to make me happy. The Ulitmates are ok for hillclimbs as I am side ways more than on the brakes.
#9 _Bomber Watson_
Posted 09 December 2005 - 09:30 PM
i have 2500's on my car....i'm definitaly happy with them.
#10 _draglc_
Posted 10 December 2005 - 11:59 AM
i have $36 supercheap ones, but thatll be fixed soon enough! gets a bit hairy sometimes hehe
