LSD or normal diff? Whats better??
#1 _Joanne_
Posted 09 March 2006 - 01:05 PM
Just wondering what you all think i should get, an lsd or a normal diff?? I need a new diff in my lx but im not sure what to get.. my tires are pretty fat at the back (i dont know what exact size but they are about double the width of my front tires-dont know if that makes a difference to what diff i should get).. my boyfriend is forcing me to get an lsd!! but im not sure if i really want an lsd coz id be a bit scared that i was going to loose control going around corners and doing burnouts & stuff if both wheels spin, whereas if i get a normal diff then only 1 wheel will spin.. are you more likely to loose control of your car with an lsd or a normal diff??? also my boyfriend said that if i get a normal diff rather than an lsd then ill lose about 1 second or more on the 1/4 mile.. is that true?
Posted 09 March 2006 - 01:14 PM
Posted 09 March 2006 - 02:09 PM
problem is if your lx still has a banjo diff LSD centres are expensive....and still fragile...big tyres...big horsepower means banjo no go!
and 1 second is a bit of a big call.
Sounds like you wont have to worry about it tho...looks like you are headed towards getting your car confiscated.
#4 _Joanne_
Posted 09 March 2006 - 02:34 PM
either way whatever it is im planning to change the diff ratios on my new diff so it will hopefully go a bit faster, and im getting a bigger cam & a slightly smaller carby coz ive got a 650 holley on there atm which is too big, so hopefully performance will improve a little soon..
#5 _Joanne_
Posted 09 March 2006 - 02:36 PM
yeah im planning to get a whole new diff as i can already tell that the banjo is not strong enough, if i put a new centre in the diff ive got now im still going to have the same problem of it not being strong enough.. i was thinking of putting a ford 9inch but i think im just going to put a salisbury 10bolt now..
why am i headed towards getting my car confiscated?? there is absolutely no defects on my car and i drive it sensibly..
#6 _Herne_
Posted 09 March 2006 - 03:20 PM
Both 253's and 308's are marked on the block. The forging is on the passengers side when looking at the car if I am remembering correctly. Of course if the 253 was a stroker then the block will still say 253.
Herne
#7 _Loki_
Posted 09 March 2006 - 04:52 PM
You are more likely to lose control with an open diff than an LSD.are you more likely to loose control of your car with an lsd or a normal diff???
Don't worry..I was trying to express humour.my boyfriend is forcing me to get an lsd!!
and
If you do that on the street...it won't matter what type of diff you have..when you are walking.
#9 _Joanne_
Posted 09 March 2006 - 05:54 PM
FastEHHolden - oh i understand now (sorry), well its my car and my money so in the end its not up to my boyfriend really, hehehe
oh sorry, i see what you mean about getting my car confescated, i should have been more specific.. I definatley dont or wont do burnouts on the street!! ive done 2 burnouts at my grandparents house (they have their own land) but they nearly confescated my car off me!! and im planning to take it to wsid wednesday nite street meet where you have the option to do a burnout before you race & i would definatley choose to do a burnout.. & also because im still learning to drive manual, if i take off too fast the wheels occasionally spin a bit.. but yeah, sorry i understand how you would have taken it, but i dont do burnouts on the street unless its un intentional..
#10 _Herne_
Posted 09 March 2006 - 06:18 PM
I hope this helps.
The engine is currently on an engine stand being prepped for painting and thus is on it's side.
It is a red block HX/HZ 253.
Herne
#11 _keith1962_
Posted 09 March 2006 - 06:21 PM
The best way to look and see if it is a 253 or 308 is to lye under the left hand side front. Look at the engine block and you will see in big numerals 253 or 308 on the side of the block. Now that is the best way to tell what it is.
Keith
#12 _Torana482HP_
Posted 09 March 2006 - 06:39 PM
#13 _Joanne_
Posted 10 March 2006 - 08:36 AM
Posted 10 March 2006 - 11:14 AM
To answer your original question, An LSD will always outperform an open centre diff.
I'm sure you mean when your doing burnouts at the drag strip ( )that its safer to have one wheel not spinning - thats not the case! Its more contolable and more predictable if you KNOW that both wheels are going to loose traction when it happens. Its bad when one does and one doesnt cause the car can turn violently because of the wheel thats not frying!
The reasons for an LSD are as follows.
Limited slip Diffs act by using some kind of clutch between the two axles. When one wheel looses traction ( say its off the edge off the road on the gravel, OR over a hole) then the clutches begin to work and direct drive to both axles equally.
Open centre diffs wont do that, all the power will go to the wheel that has the LEAST resistance ( the one on teh gravel or over the hole) and the car will begin to turn, or if your stationary it wont move at all!
LSD are really good because they act as an open diff when cornering allowing the diff to do its job ( allowing the inside wheel to turn slower compared to the outside wheel) so the car drives beautifully, but also has the added safety of having both wheels driven when its needed.
I dont know what idff you have in the car, and depending on if its a strong diff or not might mean that for now, you stay with an open centre, but if its the diff your going to keep for a long time.. I would go LSD without a doubt! To give you an example.. I'm running a 9" Diff in my HQ coupe and have just removed the LSD centre to change ratios. The new diff has a mini spool which means that both axles are always locked together and its already proven to be worse to drive and ALOT noisier! I want my LSD back but with my new ratios! I would personally never consider an open diff cause my car is a performance car.
Sorry for the essay, but i thought i might try and explain how they work with examples so you can make up your own mind!
Cheers!
#15 _devilsadvocate_
Posted 10 March 2006 - 01:19 PM
Just a tip for those who might find themselves bogged, trapped in sand/mud, going uphill through a hairpin on a snow covered road etc with a normal diff, stuck with the one wheel spinning syndrome: apply the handbrake light to moderately(obviously not full on) and this will basically equalise the resistance on both wheels and get power going through both axles and can make the difference between being stranded or not. The technique can work by using the foot brake in an auto also, but obviously this makes the car harder to move as would be fighting the front brakes as well.
Edited by devilsadvocate, 10 March 2006 - 01:26 PM.
#16 _Joanne_
Posted 10 March 2006 - 02:06 PM
