Edited by hkbathurst, 09 March 2006 - 09:10 PM.
lc boot locked ????
#1 _hkbathurst_
Posted 09 March 2006 - 09:09 PM
#2 _jap-xu1_
Posted 09 March 2006 - 09:14 PM
#3 _torana05_
Posted 09 March 2006 - 09:48 PM
Hope you can make sense of this,
Andrew 2.
Posted 09 March 2006 - 10:36 PM
1. Get a slim piece of timber (or a taped up tyre lever) and wedge the boot lid up a little. Look in the gap below the lock and you will see 2x screws holding in the lock retaining plate. If you can remove those screws you may be able to pull the retaining plate down enough with pointy nose pliers to remove the lock barrell. If you remove the lock barrell you can then open the boot with a narrow longish screwdriver.
2. If you can see the mat in the boot, chances are you can see the two 1/2" A.F. bolts that hold the lower boot catch to the rear panel. Use socket and socket extensions to undo those bolts and with a bit of a wiggle the boot lid should come up.
RACV MAN
Posted 09 March 2006 - 11:06 PM
#6 _draglc_
Posted 10 March 2006 - 10:09 AM
A1
#7 _ranalj_
Posted 10 March 2006 - 11:57 AM
Posted 10 March 2006 - 01:53 PM
#9 _Yella SLuR_
Posted 10 March 2006 - 02:03 PM
We bought a 700mm extension bar from Supercheap $19, and undid the bolts that hold the lock on from the speaker holes/holes behind the rear seat in an LH. The lock was fine, but the key no longer worked.
#10 _hkbathurst_
Posted 12 March 2006 - 08:38 AM
#11 _jen3300_
Posted 13 March 2006 - 07:43 PM
heheheh made me laughGet racq out to open it, some still have the tools to do it, found out the hard way when i locked my keys in the boot!
A1
