Battery In The Boot
#1 _Viper_
Posted 05 February 2009 - 07:52 PM
IE is it better to run the main power cable under the car or route it through the cabin?
Also is it better to run a earth cable from the battery up to the enginebay or just run it to the chassis in the boot... or both? Can you ever have too many earths?
#2 _CraigA_
Posted 05 February 2009 - 08:06 PM
This has always worked well for me.
I'm not a huge fan of batteries in the boot as they must be vented to pass engineering. If you want to then running the +ve cable inside the car would be my preference but I'd check with an engineer in your state. Don't want to be going to all that effort and end up having to change it.
#3 _Herne_
Posted 05 February 2009 - 08:46 PM
Earth to the chassis in the boot and most importantly earth the engine to the chassis in the bay (we forgot that most critical point in our rush prior to Summernats ) I had to ring Jeremy to come over urgently and sort it out, I didn't realise we had overlooked the engine bay earth nor did Jeremy until he started checking for the problem. Funny thing was for the first day of use the car started and then failed completely until the fault was detected.
As for venting the battery, all you need do is run a breather pipe from the battery box through the boot venting it under the car, obviously this requires drilling a small hole.
Hope this helps
Herne
Posted 05 February 2009 - 09:06 PM
Iv seen you mention this breather pipe before. Could you explain how this pipe is installed?? Is it next to the battery/through the floor and pops out under the boot floor??I am fairly certain my +ve cable has been run under the car, not sure where he routed it though, I will need to check next time its up on the hoist.
Hope this helps
Herne
#5 _Herne_
Posted 05 February 2009 - 09:16 PM
Hi Bart, You got it, nothing technical, just from the lid of the battery box through a hole in the boot - probably be a grommet used.
I am changing the battery tomorrow so will probably vent it then, if I remember I will take a photo, providing we get around to the venting bit.
Edit***Oh if you use a fully sealed battery then no venting is required.
Herne
Edited by Herne, 05 February 2009 - 09:17 PM.
#6 _SS Hatchback_
Posted 05 February 2009 - 09:29 PM
Posted 05 February 2009 - 09:35 PM
So what size pipe, and also my battery is not in a box but it is in the boot, i suppose it still needs venting?
#8 _Viper_
Just went and had a look at my shell and looks as tho there is a channel long the edge of the floor that would be ideal for a cable to sit in (it probly is for the stock wiring, ive got no wiring in the car atm)
But yea It looks as tho it would be a safe spot to route it?
#9 _Herne_
Posted 05 February 2009 - 09:37 PM
They dont want fumes from the battery entering the cab... Size of vent pipe surely dont matter that much, use common sense.
Herne
Posted 05 February 2009 - 11:17 PM
http://www.vpw.com.a...p;PrdGrpID=3364
http://www.vpw.com.a...p;PrdGrpID=3319
A wet battery that is not vented in the boot, can cause the boot to rust out and possibly an explosion.
#11 _Viper_
Posted 06 February 2009 - 06:57 AM
#12 _Herne_
Posted 06 February 2009 - 08:32 AM
Herne
#13 _Herne_
Posted 06 February 2009 - 07:06 PM
Note the vent pipe buit in....And you wil see it can be moved to either end of the battery by removing the red plug.
The extra wire you can see with the green plug on it is a jump point, yet to be positioned properly. the other is the vent tube.
Whilst I was there I took a couple of photo's for you of one of my sponsors toys.
We didn't get my car up on the hoist today as the workshop was chockas with customers and their cars.
Going back next week to have a balance pipe fitted so it will be up on the hoist then.
Herne
#14 _torbirdie_
Posted 07 February 2009 - 10:37 AM
Run it under the car, given that you are running it twice as far, it needs to be much thicker than the standard +ve cable going to the battery. or you may not get enough voltage at the starter to crank it fast enough. Putting the cable in conduit under the car has gotta be easier than threading it through the cabin, trying to hide i under the carpet etc. If the two earths are fairly short in length, they can be conventional diameterIE is it better to run the main power cable under the car or route it through the cabin?
Edited by torbirdie, 07 February 2009 - 10:40 AM.
Posted 08 February 2009 - 12:59 PM
I ran mine down the left hand side inside the car. No lumps or bumps, very easy to do.
#16 _Viper_
Posted 08 February 2009 - 04:12 PM
But if its under the car and it gets damaged and shorts out wont the cable just glow red hot untill it melts right through? or what will happen?
In my Gemini i ran it through the cabin, and Put silicone around it where it went near anything that was semi sharp and vibrations might damage it and I havnt had a problem... been meaning to pull the seats and carpet out just to check and make sure nothing is starting to wear through.
Posted 08 February 2009 - 07:31 PM
If it shorts out it should boil/over heat the battery and that may go open circuit before the entire cable melts??Thing im worried about is if the cable shorts out if I run it through the cabin and heats up, the carpet will light on fire.. and then the whole car :/
If you feed the cable through the floor make sure you have a rubber gromet around it. You may have to put a cable tie around the cable on both sides of the gromet so the cable dosnt move inside the gromet and wear through the insulation. (just for reasurance)
Posted 08 February 2009 - 07:40 PM
Posted 08 February 2009 - 07:47 PM
Yes they come in handyA circuit breaker is a wonderful thing...
#20 _torbirdie_
Posted 08 February 2009 - 10:42 PM
I would personally run the cable inside the car, less exposure to the elements.
running the cable in suitable conduit makes that a non issue.
#21
#22
Posted 09 February 2009 - 09:58 PM
It would be very expensive to fit a circuit breaker that is capable to supplying sufficient amps for the starter.
Could use a fuse instead if cost is an issue.
#23
Posted 10 February 2009 - 12:10 AM
#24
Posted 10 February 2009 - 03:50 PM
What fuse do you have in mind to supply enough current to a starter motor?
An ANL fuse. Should be able to buy one for around the $30 mark.
#25
Posted 10 February 2009 - 05:39 PM
