Oil Surge to be fixed with sump! More info needed
Posted 10 March 2006 - 11:38 AM
For those who didnt see my question in my members projects thread i thought i might ask in here.
Since installing the new 3.7 ratio yesterday, ive noticed a fluctuation in the oil pressure when accelerating hard.
My oil pressure at anything above idle is 62Psi ( Hot), and at idle around 20Psi.
What i noticed was that as the car accelerates with more force than before, I watched the oil pressure guage fall from 62 Psi down to around 20-25 Psi... It came back when i got off the gas and the acceleration force stopped.
I'm running a 400 Smallblock chev with a blueprinted bigblock oil pump, systems 1 oil filter, oil restrictors in the galleries, deburred valley/block/heads to assist oil drainback, standard HQ type sump, and i'm using pennzoil 25-50 oil.
Any ideas thoughts or comments would be great. I'd rather not have to go for a high energy sump.. but if its going to solve this problem and stop the motor from going bang.. then i'll do it!
(Thing is... when we lift the motor out to install the sump... i might be temped to tickle it more... you know... just while its out!)
Posted 10 March 2006 - 11:39 AM
Posted 10 March 2006 - 11:53 AM
Posted 10 March 2006 - 12:11 PM
#5 _Yella SLuR_
Posted 10 March 2006 - 01:16 PM
Posted 10 March 2006 - 02:07 PM
Makka: Yeah tell me about it I Dont wanna! Nooooo stop twisting me arm! LOL
Cheers guys
#7 _devilsadvocate_
Posted 10 March 2006 - 05:01 PM
How could you tell which is happening without actually performing the fix? Dont know, would need to have some type of level recorder inside your rocker cover.
Id imagine this problem has been seen b4 in drag cars, is the overflow tube from rocker to sump a common feature?
#8 _82911_
Posted 10 March 2006 - 06:20 PM
told you some steep gears would wake that thing up!!! Still rekon you need 4.1:1` 's... <_<
Now remember what I said about .."when you get it to hook up and pull hard" A whole host of new problems will arise....
Welcome to the 1st of them pal!!!
Oil surge with the chev pick up is not all that uncommon. And if it does it on the street it is going to do it worse on the track.. Sorry not what u wanted to hear i know!
Band aid..... put another litre in the sump, and pray your front and rear gaskets are in good shape.
Better option..... get a proper sump, and place the pick up within a 1/4 of an inch of the floor of the pan and towards the rear of the sump bowl. Just remember though if it fixes it on the launch.. you get the opposite at the other end under brakes!!! Baffles and trap doors are the solution.
if you get stuck call me my phone is always on..
Cheers Greg..
Posted 10 March 2006 - 08:23 PM
Thanks greg! I'll take you up on that mate..
I'm more than happy to say it.. You were right as always!!!! I never doubted what youve said and i'm glad you were kind enough to let me know what i was in for so i could keep an eye out!!
I noticed this problem beginning to arise on teh track, but cause of my crappy acceleration it never was enough to get concerned about.. but this is!! I'm REALLY scared of starving a bearing and then spinning it under acceleration! i simply cant afford to grenade an engine!
I'm over the moon with the 3.7s, its still ok on the freeway but its UNREAL under acceleration so i think ive found my happy medium!
Anyhow.. I'm thinking about hoping for the best.. using the extra litre trick to race it at heathcote next weekend, and then going the sump.. But i'm just scared if i do race and kill the engine...... Ahhh the joys of it all!
Thanks again mate.
#10 _82911_
Posted 10 March 2006 - 09:42 PM
Struggler would prolly be more familiar with the symptoms of this than me.. but anyway....
The pick up tube on a chev is a press fit into the pump body, and they can work there way off due to vibration. Do you remember if you tack welded the pick up tube to the pump body during the engine build. Cliff would prolly do this as a matter of course.. did he assemble the pan and pump??
Cheers Greg..
Posted 10 March 2006 - 09:47 PM
Cliff blueprinted the pump and assembled everthing complete on the engine!
#12 _SSHatch_
Posted 10 March 2006 - 10:05 PM
When I rebuilt it last time I got one of the guys at work to Bronze the pick up in place!! Also made sure that the pick up was sitting only 2-4 mm off the sump.
Posted 10 March 2006 - 10:13 PM
if the pickup did fall out.. technically i would have NO oil pressure? cause the inlet hole is actually above the oil level?
Thanks for your help guys!
#14 _Yella SLuR_
Posted 10 March 2006 - 11:18 PM
Edited by Yella SLuR, 10 March 2006 - 11:19 PM.
#15 _CHOPPER_
Posted 11 March 2006 - 07:06 AM
#16 _SSHatch_
Posted 11 March 2006 - 09:54 AM
Thats kinda what mine was doing, pick up had worked loose and I would get fluctuations in oil pressure due to it sucking air, not oil.
Posted 11 March 2006 - 05:37 PM
Pat: too right mate! pain in the ARSE!
Chop: thats the plan.. Luckily this week is low on work (well.. Unlucky for teh bank balance!!)
But what i'm going to start with is to remove the oil filter tomorrowm give it a thorough oil change and use some engine oil flush to try and clear it right out... Fresh oil.. and see what it does.
The engine builder doesnt belive i could have a problem in the sump but the pickup is a definite possiblity...
Will try the oil change and see how it goes! Fingers crossed and thanks for your ideas!
Posted 25 August 2006 - 05:36 PM
Ive finally gotten the shits enough to fix this problem.
I'm going to buy a new sump, pickup, pump and install the LOT!
Now.. Choosing the sump!
While it's a street/strip car.. i want to have a baffle system that also stops sideways oil surge ( for when i do DOUGHIES... theyre just too much fun!).
I'm looking at the following Hi-Energy Pans. Can you guys let me know what you think and reccomend?
Street/Strip PRO ELIMINATOR pan
Model: HE3210 SB Chev. HQ Mesh, Gate, Pick Up $576.00
OR
HE3210-1PCE SB Chev. HQ Mesh, Gate, Pick Up, 1 Piece Rear Main, $621.48
I'm not sure what they mean by 1 piece rear main... My 400 has a neoprene rear main.. but its defintiely 2 piece!?!?
OR
CLUB RACE PAN
Club Race Pans-CHEVROLET, suit club circuit race cars
HE8249 Club Race SB Chev. HQ, 3 Gates, Pick Up $840.27
HETEMP-3 Fit 1/8" Temp Sender Fitting $14.87
Has anybody used these pans? and what could you reccomend? I cant find any information on Russel oil pans.. apparently theyre just as good, but i cant find any info on them!
I want to get this done, done ONCE and fixed for good.. i'm SICK of playing with it!!
Cheers!
#19 _SSHatch_
Posted 25 August 2006 - 06:11 PM
It means exactly as it says.HE3210-1PCE SB Chev. HQ Mesh, Gate, Pick Up, 1 Piece Rear Main, $621.48
The rear main is a one piece seal, looks like a donut.
You simply pop out the seal and tap a new one in, unlike the two piece that you and I have that require the crank out to change the seal.
Most later model cars run a one piece seal as its much much cheaper to replace as you dont need to pull th engine apart to do so.
Posted 25 August 2006 - 06:24 PM
Many thanks for that!
I'm leaning towards the circuit sump.. I think it'll work for teh drag racing as well as the "circle work" ;P
#21 _alx ss_
Posted 26 August 2006 - 12:08 PM
#22
Posted 26 August 2006 - 12:57 PM
I'm going to go for the circuit pan, that way i know under all conditions we'll be right!
Can i ask, what did you have to do oil filter wise?
I was lucky enough to be able to get my car onto a 4 post hoist this morning and i had a really good look under it...
It looks like if i go for a winged sump, that i'll need to go remote oil filter because i wont be able to get th filter off! ( its a prick of a job as it is!).
Hmm one thing after another! Do you happen to have any dimensions from your sump? the wing dimensions etc?
THanks for your help mate!
#23 _alx ss_
Posted 26 August 2006 - 01:59 PM
#24
Posted 26 August 2006 - 02:08 PM
#25
Posted 26 August 2006 - 06:18 PM
I'm running a Bigblock oil pump in the small block.. Apparently this is a common upgrade! My question is, is there any difference in the pickup i'm going to need? THe sump comes with high Energy's race pickup which i want to use, but does anyone know if its the same if your using a bigblock pump VS a smallblock one?
What pump are all the chev guys here using now?
