Thermo fans
27 replies to this topic
#1 _SLR Goat_
_SLR Goat_
Posted 10 February 2009 - 06:52 PM
Looking at different brands of thermo fans just wanting any opinions on certain brands the main ones im looking at are
Spal
Davies Craig
Cheers dennis
#2 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 10 February 2009 - 07:04 PM
AU Fans FTW - See the sticky thread above!
Though i'm looking for a SPAL controller to turn teh buggers on and off!
Cheers!
#3 76lxhatch
  • 7,218 posts
Posted 10 February 2009 - 09:32 PM
The AU fans do look the goods and that's on the one-day list. At present I just have a couple of cheapies, I figure that at least if I have two fans they can't both die at the same time! Get a decent thermostat though
#4 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 10 February 2009 - 09:42 PM
I use a PWR unit. Good one.
:spoton:
#5 dattoman
Posted 10 February 2009 - 10:26 PM
The AU fans have a full shroud so they pull air thru the whole rad
A big single or duals with no shroud do not
I'd go AU's
They can be wired together or individually to turn on and shut off at varying temps
#6 ls2lxhatch
  • 5,335 posts
Posted 10 February 2009 - 10:41 PM
PWR fit SPAL fans. I suspect your fan will be a 16" curved blade part #30102048 ( EF3534 ) rated at 2350 cfm or possibly the SPAL extreme #30102113 (EF3634 ) rated at 3000 cfm.
http://www.spalusa.com/
You can buy SPAL fans cheaper from REPCO than from PWR.
I have 2 x Derale 16925 fans rated at 2200 cfm each. The motors are Bosch.
http://www.derale.co...le-rad-fan.html
Edited by ls2lxhatch, 10 February 2009 - 10:47 PM.
#7 _SLR Goat_
_SLR Goat_
Posted 10 February 2009 - 10:42 PM
I was planning to mount the fan on a shroud aswell i was mainly after feedback on the brands listed i now that they all seem to vary in how much cfm they pull thru its going to be manually switched anyway just after feedback from anyone who has used them
A9X-yours is a pwr one hows would u rate it im taking a guess that its roughly 16inch what sorta price r they?
cheers dennis
#8 _SLR Goat_
_SLR Goat_
Posted 10 February 2009 - 10:56 PM
Cheers!
I have being reading up on those spal controllers they look pretty sweet
#9 ls2lxhatch
  • 5,335 posts
Posted 10 February 2009 - 11:49 PM
Some fan manufacturers make dubious claims about their performance. As a general rule of thumb a fan should draw around 1 amp per 100 CFM. You will note that the Derale fans draw 23.4 amps for 2200 CFM. The SPAL fans also follow the general rule.
Permacool however estimate their 16" fan #19115 will produce 2950 CFM drawing only 9.5 amps. :spit:
http://perma-cool.co...Cat_page16.html
#10 _keith1962_
_keith1962_
Posted 11 February 2009 - 05:04 AM
Now as for working in this industry which i have done for many years, these are my thoughts.
Spal - great producers of fans
Davies Craig - 1 of the best in the industry
Ice - cheap crap
AU Falcon fans are still 1 of the cheapest ways to go & most effective
cheers Keith
#11 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 11 February 2009 - 04:49 PM
So Keith... when are you guys going to get the SPAL fans and controllers in stock!!
:tease:
#12 _keith1962_
_keith1962_
Posted 11 February 2009 - 09:17 PM
Prob never but let me ring around in the morning & i will let you know Rob ok
cheers Keith
#13 _the gts_
_the gts_
Posted 12 February 2009 - 09:46 AM
what is the best alternative option if you dont want to butcher AU fans to make them fit
#14 _1uzbt1_
_1uzbt1_
Posted 12 February 2009 - 10:58 AM
mondeos,fit like a charm on torana/kingswood v8 radiators
#15 76lxhatch
  • 7,218 posts
Posted 12 February 2009 - 11:19 AM
I thought the idea of the AU fans was that they require little to no butchering?
#16 GML-31
Posted 12 February 2009 - 11:35 AM
if you go twins... do not wire them together, use a seperate relay for each, you can have them on one switch if you want. I use relays with fuses built in.
#17 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 13 February 2009 - 02:14 PM
^ good advise! they draw a HEAP of power on startup!
#18 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 13 February 2009 - 08:51 PM
cheers dennis
Hey Dennis.
I rate it pretty high.
Alloy welding is excellent, fit and finish was spot on, it bolted up without fuss.
The car holds between 90 and 100 degrees regardless of how hard i push it, I got held up in a line at the end of last years targa at the end of the day, it creeped to just over the 100 before the run, and by the end of the run it had pulled it back to the 100. by the time we stopped, threw helmets in the back and got a k or 2 down the road it was back to 90.
I don't run a shroud and haven't blocked off the airflow through the radiator like i probably should. I am playing with undertrays but can't say it has made any difference.
There are a number of things i wish to change on the car (are we ever finished) , but the radiator isn't one of them.
Good luck,
#19 _SLR Goat_
_SLR Goat_
Posted 14 February 2009 - 02:21 PM
Thanks for the replies im leaning towards a Spal fan can get one thru repco for a good price
Cheers dennis
#20 _keith1962_
_keith1962_
Posted 14 February 2009 - 07:41 PM
What do you call good price???
cheers Keith
#21 _SLR Goat_
_SLR Goat_
Posted 14 February 2009 - 09:38 PM
cheers Keith
Bout 180 mark at trade price
#22 _keith1962_
_keith1962_
Posted 15 February 2009 - 07:18 AM
Hey Dennis
What about using Davies Craig fans & what size are you looking at buying?????.
As i would be able to sell you this brand of thermo fans at a great price.
cheers Keith
#23 _SLR Goat_
_SLR Goat_
Posted 15 February 2009 - 10:49 AM
Hey Dennis
cheers Keith
pm sent
#24 _HZ_KINGA_
_HZ_KINGA_
Posted 15 February 2009 - 03:10 PM
I have both AU fans and Spal fans. both work awesomely.
Fans in both my cars are controlled with just a tridon temp switch (with relays of course). (You can get them in various temp ranges and threads)
Doesn't take much effort to modify the shrouds on the AU fans or make a shroud like I did for the Spal fan. Posted Image
#25 _76S.L.R_
_76S.L.R_
Posted 17 February 2009 - 06:40 PM
Ive been eyeing off the Spal Fan Controllers,I can find no distributer of these in Australia though and are Expensive: anyone know if the SPAL Controller will work with my AU FANS??:still havent sorted out my AU FAN wiring yet either! the sparky the wired them up did it wrong and they come on when trying to crank the motor if the Collant temps hot.
The AU Fans draw heaps of power!!,its very noticeable when driving along and they start up= maybe my Alternators not big/good enough( standard 308 alt).............
