LC GTR DOOR RUBBER
#1 _vtss_
Posted 10 March 2006 - 10:57 PM
#2 _Bomber Watson_
Posted 10 March 2006 - 11:05 PM
#3 _vtss_
Posted 10 March 2006 - 11:15 PM
Edited by vtss, 10 March 2006 - 11:19 PM.
#4 _WYLDLC 6_
Posted 11 March 2006 - 07:20 AM
Hope this helps.
Cheers Chris.
#5 _lcgtr_
Posted 11 March 2006 - 05:40 PM
#6 _JBird_
Also, press the CAPSLOCK button so its off when you type so it doesn't SEEM LIKE YOU ARE SHOUTING ALL THE TIME
Posted 11 March 2006 - 08:36 PM
It was going to be the first thing I railroaded the Rares Spares guys about on the members night
jpxu1
#8 _boynuz_
Posted 12 March 2006 - 02:38 AM
Les gave us some magic spray to try, What we did was spray the rubbers then shut the doors for 24 hours.
We done this 5 times in the last 2 weeks and the doors shut perfect with out having to slam them.
My doors weren't perfect as well vtss had to re align them before fitting the rubbers, On a car that everything is perfect you will never have problems unless rubbers are not fitted correctly.
As vtss has said the front vent rubbers are very rough and can be improved.
#9 _vtss_
Posted 12 March 2006 - 10:03 AM
YOU SPRAY RUBBERS AFTER YOU FIT AND ARE GLUED IN FIRST THEN THE NEXT DAY SPRAY THE MAGIC SPRAY . YOU CAN GET FROM RARE SPARES. DO THIS TWO OR THREE TIMES LIVE IT EACH TIME 24HOURS WITH DOOR SHUT AND SEE HOW YOU GOvtss do u spray the Magic Spray on before or after the fitting?
#10 _vtss_
Posted 12 March 2006 - 10:14 AM
THE MAGIC SPRAY SOFTENS THE RUBBER SO IT CAN MOULD TO YOUR DOOR JAM FRAME .THAT HOW ITS WAS DONE WHEN THEY WERE MADE FROM FACTORY THEY ONLY HAD TO SPRAY (THE SPRAY THEY USED NAME WAS UNKWON TO HIM ) ONE TIME ONLY .MY FATHER INLAW TOLD ME THAT BECAUSE HE WAS ON THE GMH ASS LINE FITTING THEM FROM 1964 TO 1971Yeah.......... I want to know what this magic spray stuff is as well. I've been slamming my doors for years and they aren't getting any better
jpxu1
REMEMDER WHEN SHUTTING YOUR DOORS SHUT FROM WINDOW FRAME NOT DOOR HANDLE.
IF ANY NEED HELP T FIX THERE DOORS UP JUST LET ME KNOW
Edited by vtss, 12 March 2006 - 10:25 AM.
Posted 14 March 2006 - 08:49 PM
I've just done a search on the Rare Spares site and 'magic spray' doesn't come up
So, come on Les- what's this 'magic' stuff called these days? AND I suggest you organise a special delivery so there's plenty on hand at the members night
Cheers,
jpxu1
#12 _finer70_
Posted 14 March 2006 - 09:01 PM
Don't know just what is in it but it smells the same as the tyer spray. Possibly a similar base constituent.
I have sprayed one of my LC door rubbers. Not noticed a great deal of difference yet. probably will need several applications to get good penetration to increase the suppleness of the rubber. Lets face it, the rubber will need to relax to allow it to better mould itself to the required shape.
If it did this overnight I would not expect the rubber to last very long as its durability would probably deteriorate just as rappidly.
Patients is a virtue.
#13 _82911_
Posted 14 March 2006 - 10:24 PM
I would like to know if this "magic spray" contains any silicone compounds???
I would like to spray my rubbers too... but not if it means that the next time i try to touch up my paint I end up with fish eyes everywhere!!!
Cheers Greg..
Posted 15 March 2006 - 12:26 AM
On the tin of rubber magic is claims to be good at restoring all rubber stuff - I am trying it on all sorts of stuff like bump stops and it does make them look heaps better - good stuff to have around in general.
M@
#15 _bad gpak_
Posted 15 March 2006 - 08:41 PM
no good for hard rubber like stops only good for rubber grade like door and boot seals . all l can see its abit like a silicon spray not good to use to many time will stuff up rubbersI have used rubber spray on my door rubbers and left it overnight 3 times now - it has made a slight difference but the major improvment was in getting my panels actually aligned.
M@
make then britale as they get older
Posted 15 March 2006 - 11:42 PM
I re-read the tin and it does say door seals, rubber mats and tires etc. .. bit vauge this last one.
These bump stops I tried it on are 30 Y/O things - made them look a lot better (they were already a tiny bit cracked on the surface and squashed).
I do reckon it does something for the door seals though - interresting to note above they used that sort of stuff at the factory when they made them.
M@
#17 _vtss_
Posted 16 March 2006 - 07:16 PM
Posted 16 March 2006 - 08:06 PM
#19 _vtss_
Posted 19 March 2006 - 10:17 PM
Posted 20 March 2006 - 03:54 PM
Sounds pretty clear.
It does not actually tell you the active ingredients though.
M@
#21 _lcgtr_
Posted 23 March 2006 - 08:34 PM
#22 _dave720gtr_
Posted 26 March 2006 - 12:25 AM
Thay should of come in with the rubbers wether stripsALL I HAVE TO FIT ON NOW ARE THE DOOR OUTER WINDOW RUBBER WEATHER STRIPS ,BUT HAVE TO FIND THE CLIPS FIRST TO HOLD THEM ON , SHOULD OF BEEN SUPPLYED BY RARE SPARE IN RUBBER KIT AS WELL ,AS EVERY ONE KNOWS THEY RUST AWAY TO DUST .LOOKS LIKE L'LL BE MAKING THEM THIS WEEKEND
my ones came with the clips thay were from clark rubber you will be flatout making them look tricky spring steel two. i got the full kit of outer/iner wether stips $136 as i say thay were in the bag all the clips and i also got my 1/4glass rubers there and thay look good no probs with the doors not shuting ethere
dave.....
#23 _boynuz_
Posted 27 March 2006 - 04:55 AM
Hi dave720gtr i purchased the full rubber kit from rare spares and it didn't have the clips. I even asked at the preston store and they didn't have them listed.
That means that clarks rubber must be getting them made it would be interesting to see how their rubbers are compared to rare spares.
I will go their and ask if they sell the clips separate it will save us a lot of time in trying to make them.
