Hopper Stoppers Installation Query
_Viper_
Posted 11 March 2006 - 07:47 PM
ok here is what the instructions say exactly..
"6. Grease the new mounting hub and wheel bearing sets and install the inner bearing, fitting the grease seal to the stub axle. Install the hub onto the stub axle, install the outer bearing, refit the bearing tab washer and fit centre nut, tightening to recommended preload, which for taper bearings should allow a small ammount of end float rather then too tight which will destroy the bearings. fit the original castle washer and new split pin. Refit grease cap"
ok now my problem is with the "refit the bearing tab washer and fit centre nut" as when i removed the old brake setup it didnt have anything like that i think... so i figured there just talking about the washer and castlated nut.. but then abit further on it says fit castle WASHER.... and i donno if thats supposed to say nut or what?
so yea if anyone could clarify on this that would be great
-Clint
_CHOPPER_
Posted 11 March 2006 - 08:41 PM
Posted 11 March 2006 - 10:17 PM
_Viper_
Posted 12 March 2006 - 02:13 PM
_CHOPPER_
Posted 12 March 2006 - 04:53 PM
_Viper_
Posted 18 March 2006 - 09:06 PM
-Clint
Edited by Viper, 18 March 2006 - 09:07 PM.
_mra9x_
Posted 18 March 2006 - 09:48 PM
Posted 19 March 2006 - 08:32 AM
Simmons 14/15 and 16's wont fit, you need 17's or spacer on the smaller sizes.when i bought my kit the guy told me that with some wheels especially simmons they will touch however they also sell a spacer to pack the wheel out a touch
VT commodores run 15's standard and they just clear the calipers.
Posted 19 March 2006 - 11:56 AM
holdenuc
_Viper_
Posted 19 March 2006 - 12:39 PM
-Clint
_CHOPPER_
Posted 19 March 2006 - 02:13 PM
#1 They are original equipment for that particular car. ( ie:xu-1 spacers on a non xu-1 is not legal )
#2 The spacer it physically attached to the hub, not just held in place when the wheel is tightened.
Otherwise, they are illegal.
Posted 19 March 2006 - 02:57 PM
We don't have any spacers I'm afraid
I'd refrain from taking anything of the caliper if its at all possible.
As Chop said maybe you could clean up the welds on thw eheel alittle and see if this helps
Failing that yes some thin spacers
Rego doesn't like them........ but how will they know they are there ?
I doubt they will take a wheel off..... but you never know
If the spacer is rivetted or bolted to the wheel so its permenant would that be considered legal ?Or alternatively screwed to the hub would work too
Posted 19 March 2006 - 08:15 PM
_CHOPPER_
Posted 19 March 2006 - 09:31 PM
Posted 20 March 2006 - 08:14 PM
Done deal, fixed, nice and easy. Nice and legal and safe. All sleep easy now.
_CHOPPER_
Posted 20 March 2006 - 08:20 PM
_Torana482HP_
Posted 21 March 2006 - 07:23 PM
My tyres only last 12 months at the most, but I do a lot of KM in those 12 months.
Do your rear tyres do more km's than your front tyres like my car?
Funny how that can happen
lol.
_CHOPPER_
Posted 21 March 2006 - 08:06 PM
