no feeling in the brake pedal.
Posted 12 March 2006 - 02:23 PM
Posted 12 March 2006 - 02:30 PM
Sounds like the reaction disc in the booster.
Datto is the man to talk to.
RACV MAN
Edited by rodomo, 12 March 2006 - 02:31 PM.
Posted 13 March 2006 - 01:56 PM
#4 _UCV80_
Posted 13 March 2006 - 05:51 PM
iv got this same problem... and it doesnt feel safe!
slowly push down then WHAMO! everyone gets thrown forward..
how do we fix our brakes?
,Nathan
Posted 13 March 2006 - 06:17 PM
#6 _CHOPPER_
Posted 13 March 2006 - 06:39 PM
Posted 13 March 2006 - 07:30 PM
Apply your brakes hard (stationary not driving) and slip your foot off to the side so the pedal comes back quick. Do that a few times and see if it helps.
From memory something in the reaction disc area sticks if left sitting. Obviously this a temporary fix and I am only suggesting this for the sake of diagnosis. Best to have the system checked.
RACV MAN
#8 _jabba_
Posted 13 March 2006 - 08:46 PM
#9 _UCV80_
Posted 13 March 2006 - 09:27 PM
i never had my booster appart. iv been told never to touch the boosters as there hard.
,nathan
Posted 13 March 2006 - 10:02 PM
Does sound like a missing reaction disc in your case
Posted 15 March 2006 - 10:12 AM
Posted 15 March 2006 - 03:07 PM
RACV MAN
Posted 15 March 2006 - 07:09 PM
It has been 10 yrs since I rebuilt one..might be time to revisit this.
Posted 15 March 2006 - 10:56 PM
Not out of the booster
Look for it here
When the master cylinder is pulled forward to replace it the rod may come forward with it and the disc falls out of its hole
Then when you put the master back you have excessive travel
When you drive after the travel you have touchy brakes.
Pull the master forward...... remove the front seal and pushrod
Shine a torch into the booster. If you don't see a rubber disc in the centre of the booster this is your problem
Go buy a new one and refit it into the booster
To refit it put a dob of rubber grease on the fat end of the rod..... to stick the disc to it while you put the rod back in. Don't use normal grease or petroleum based products or silicone to do it.
Posted 16 March 2006 - 12:31 PM
