UC Torana 10bolt Diff
#1 _LX_SSnatch_
Posted 04 March 2009 - 10:07 PM
Just bought a UC torana 10bolt salisbory (actally classed as 8bolt) lol anyway its a standard diff our of a UC 3.08 ratio
wat i would like to know is wat LSD's will fit this diff as i know geniune 10bolts LSD's r getting hard to find?
i would also like to try and convert is to discbrake if possible?
Any advice would be exellent
cheers matt
#2 _evil UC hatch_
Posted 04 March 2009 - 10:35 PM
#3 _The Baron_
Posted 04 March 2009 - 10:39 PM
(Also early commodore small salisbury too I would think)
So Bango LSD should fit.
As the centres are interchangeable, there is practically no additional strength going to a UC diff over your original Bango.
Are you also aware the UC diff will not fit the LX without major modifications to the top arm arrangment.
There are also no new UC rear disc's available that I know of too.
Sorry about the bad news chief.
Posted 05 March 2009 - 05:50 AM
1) few Banjos had fine spline axles which the Salisburys all had
2) the Salisbury housing is a little stronger which saves the axles and bearings
neither of these is very significant though and the Banjo LSD is a small unit, most are worn out.
And as The Baron said also a UC diff will only fit a UC.
#5 _Herne_
Posted 05 March 2009 - 08:53 AM
Hi all
cheers matt
This is the first time that I have heard a UC diff called a 10 bolt.
The UC diff is a POS when compared to a proper 10 bolt.
I hope you are not kidding yourself here into thinking its going to be anything like a 10 bolt.
I will add, in its own right a UC diff is ok.
Herne
Edited by Herne, 05 March 2009 - 08:55 AM.
#6 _LX_SSnatch_
Posted 05 March 2009 - 05:41 PM
ok so early commodore and bang-go LSD's centres fit..... ok ok so does anyone have one forsale??? lol
thanx for the feedback
cheers matt
#7 _UNVSM8_
Posted 05 March 2009 - 06:13 PM
Herne
UC diff's actually arnt that bad! ive got my standard UC diff in behind my 304i v8 and it hasnt let go yet and i wouldnt say im kind to it!
LX SSnatch let us know how u go with the lsd center i'll be interested to here if it works
Cheers Ben
Edited by UNVSM8, 05 March 2009 - 06:15 PM.
#8 _mumstaxi_
Posted 05 March 2009 - 08:21 PM
Im sure i was told the centres differ to a banjo tho ? a important thing to maybe check was what spline axels you have, as you need to get a centre to match.
From memory,they come in 25,28 and 32 spline ,i had very coarse 25 spline axels from memory and was told the diff centres that fit came from a early model 6cyl and 4.2 Litre V8 commodore (not the 5Litre V8 commodore tho) sedan and wagon centres the same.
They are supposed to be as strong or maybe a bit stronger than a banjo (as in,not strong at all), depending on your car (auto,manual etc) and if you treat it nice you may be suprised how long it will last behind a bit of HP, i know i was/am.
I got a LSD commodore centre from VIC, as i could not find one in QLD at the time,so i wish you luck.
MT
Posted 06 March 2009 - 05:42 AM
Posted 06 March 2009 - 06:24 AM
Posted 06 March 2009 - 08:11 AM
Salisbury_Dsc00599.jpg 269.42K 41 downloads
Small Salisbury as fitted as std to a UC & Commodore
largesalisbury.jpg 31.07K 41 downloads
Large Salisbury or 10 bolt
Warren
Posted 06 March 2009 - 10:34 AM
Warren I didn't realise that the hemisphere didn't fit; I know that you can use them to change the Banjo to fine spline so it must be swapping side gears only...?
End result I was wrong! Banjo LSD is no good to you, you need one from an early Commodore.
#13 _The Baron_
Posted 06 March 2009 - 04:42 PM
#14 _LX_SSnatch_
Posted 06 March 2009 - 05:31 PM
ok so does anyone have a early model commodore LSD centre they wanna sell?
lol i know its a long shot lol worth a try
Cheers Matt
Posted 06 March 2009 - 06:56 PM
hmm... what would one be worth....
#16 _on the limit_
Posted 07 March 2009 - 07:44 PM
#17 _keitho5770_
Posted 19 March 2009 - 05:32 PM
Posted 19 March 2009 - 05:40 PM
#19 _Brad1979UC_
Posted 21 March 2009 - 12:16 AM
might be a way to go, yeh interesting to see what kind of dollars we're talking too, and could you use existing UC salisbury axles with an LSD salisbury como centre?...when did they change to borgs?
Posted 21 March 2009 - 05:42 AM
