LJ Diff ratio?
#1 _lexa_
Posted 14 March 2006 - 10:19 PM
Posted 15 March 2006 - 03:14 AM
Put in a taller ratio diff say a 3.36 and it will feel a bit more punchy.
But not recomended your your on the freeway a lot. Unlease you like using lots of fuel.
#3 _73LJWhiteSL_
Posted 15 March 2006 - 09:33 AM
Crawl under the car and have a look on the metal ring thats right behind the uni joint facing the uni on the front of the diff housing. If it hasn't been played with it will be accurate.
Another way to check would be by what reves its doing at 100kph. With a 2.78 at 100kph the rpm should be ~2500, with a 3.08 ~2700, with a 3.36 ~3100 and with a 3.55 ~3300. This is with 205/60R13 tyres, but the standard (175/75R13s) should be simialar.
Steve
Edited by 73LJWhiteSL, 15 March 2006 - 09:34 AM.
#4 _lexa_
Posted 15 March 2006 - 11:31 AM
#5 _73LJWhiteSL_
Posted 15 March 2006 - 11:40 AM
If you have a stock 173 or anything smaller I would recommend a 3.36 (which is what i am running 173,m20, 3.36) or if you have a stock 202 or worked 173, 186 or 202 go with the 3.08
But then it depends what the car is used for and if you prefer highway or taking off in a hurry.
Steve
Edited by 73LJWhiteSL, 15 March 2006 - 11:41 AM.
#6 _lexa_
Posted 15 March 2006 - 12:14 PM
HP block
bore size: 3.665 inches
capacity: 190 cubic inches
stroke: standard 186
compression ratio: 9.2:1
balanced
pistons: ACL flat tops
rings: ACL moly
starfire rods
ARP rod bolts
ACL bearings
LC XU1 spec cam
powerboss hydrolic lifters
street terra roller rockers
ACL gaskets
and a celica 5 speed i shouldnt have any problems with the diff? in the future i will upgrade but for now i'm just trying to get it on the road
#7 _73LJWhiteSL_
Posted 15 March 2006 - 12:53 PM
Steve
#8 _lexa_
Posted 15 March 2006 - 02:03 PM
#9 _high_rpm_
Posted 15 March 2006 - 02:22 PM
#10 _lexa_
Posted 15 March 2006 - 02:42 PM
Posted 15 March 2006 - 02:53 PM
RACV MAN
#12 _devilsadvocate_
Posted 17 March 2006 - 08:12 PM
One can use a formula for 100kmh in top(direct) gear :
diff ratio = (rpm x TC)/1666 or at 60kmh: diff ratio = (rpm x TC)/1000
TC = tyre circumference in metres. How accurate is this with a trimatic? Don�t think they lock up completely at 100kmh?
TC can be found for any tyre size at: http://www.powerdog.com/tiresize.cgi, there are other sites on the net that will do all the calcs for you.
It is more accurate to get your TC by measuring it directly, especially if partially worn etc. A good way to do this is to mark the surface of the tread with some liq paper and roll the car along some smooth ground. Measure the distance bw spots on the ground and you have effective rolling circumference. Possibly rolling circumference increases slightly with speed, but guessing not by much.
An accurate and quick way to establish diff ratio(if unknown) is to get first hand measurements from the axles and tail shaft:
Jack up one of the rear wheels(or both if lsd), release handbrake put in neutral(chock front).
Put an easily seeable marker, perhaps a loop of electrical tape stuck around the tailshaft with a portion hanging off.
Rotate one of the road wheels exactly 10 times and count the corresponding rotations of the driveshaft.
31 rotations = 3.08, 28 rotations = 2.78, 39 rot =3.9 etc.
What sized rear tyre you intend to run. Do factor in that for example a 195/65/14, which could fit on your vehicle is 6% larger than a 205/60/13, over half a diff ratio.
#13 _lexa_
Posted 17 March 2006 - 09:50 PM
#14 _draglc_
Posted 17 March 2006 - 10:07 PM
A1
Posted 17 March 2006 - 11:58 PM
#16 _devilsadvocate_
Posted 18 March 2006 - 01:55 PM
thankyou very much
