I picked it up yesterday. off my workmate whos owned and mistreated it for the last 15 years or so.
The body is shagged. only alrite panels are nosecone bonnet and boot. and possibly 2 doors.
its got a mildly worked 179 hp motor in it with yella terra head, the block was balanced and blue printed when it was done up so he says.
Genie extractors, cain manifold and 350 holley.
M20 four speed and 3.36 old banjo according to the id tag under bonnet. code GV4.
Just wondering if the block is worth hanging onto. because the motor does not run. it cranks over and just backfires very badly throught the carby. on the weekend i hope to inspect to see whats wrong with it. possibly blown out a piston or head gasket.
any ideas appreciated.
Just bought a 4 door lx
_UCMEGO_
, Mar 16 2006 04:30 AM
9 replies to this topic
#1 _UCMEGO_
Posted 16 March 2006 - 04:30 AM
#2 _Keithy's_UC_
Posted 16 March 2006 - 07:02 AM
Keep a hold of the engine! I have a worked 179HP in my UC, i believe that these motors are less appreciated than they should be! Basically they are a 186 with a smaller bore! This means that you can bore it out 120thou in total in comparison to the 186 and 202's 60thou! This is good news for anyone wanting to rebuild one of them!
Mine's got the same gear as yours (350 Holley on CAIN manifold and i have pacemakers), ive got a bit of internal good stuff and some other nifty worked parts on mine too! Good enough for a 14.8 down the 1/4mile...
As for the shell.... If its got too much cancer, i'd send it to someone who recycles parts as it's probably gonna cost you a fair bit! As long as the running gear is in a 'restorable' condition (within reason), i'd keep it and get rid of the shell! Locate yourself another LX (if that's the model you want) and build up your running gear from the other one and chuck it in the new one! You'll find a decent LH - UC torry/sunbird for less than a grand these days! Ahh, the possibilities!
Keith
Keith
#3 _SL/R SS A9X_
Posted 20 March 2006 - 03:25 PM
Whats the boot floor like ?
Any holes?
Rust?
Jason
Any holes?
Rust?
Jason
#4 _UCMEGO_
Posted 21 March 2006 - 06:59 PM
hAVE NOT HAD A GOOD LOOK AT IT AS YET BUT I WILL 2MORROW AND LET U KNOW IT HAS A TACHO DASH CLUSTER IN IT ALSO IF ANYONE IS INTERESTED.
#5 _UCMEGO_
Posted 21 March 2006 - 07:03 PM
FOUND THAT THE NUMBER 5 INTAKE VALVE ROCKER WAS LOOSE! it runs now.
what can be done about the rocker adjusting nuts on these cylinder heads. most of the ones on this hp motor are not very tight on the stud and they would freely vibrate loose> I tried giving one a few hits with a center punch it made it lock up a bit better.
#6 _CHOPPER_
Posted 21 March 2006 - 07:10 PM
I bought a set brand new last year from GMH. Only cost a couple of bucks for the lot.
#7 _SL/R SS A9X_
Posted 22 March 2006 - 04:25 PM
UCMEGO do you have any pic of the boot?
Jason
Jason
#8 _UCMEGO_
Posted 23 March 2006 - 07:08 AM
No i dont but i can get some up if u want what do u want the boot lid or the floor. looked at the floor yesterday it has got one small rust hole on the left hand side3 just rear side of wheel well. and a big ugly hole on the far right hand side at rear other than that its pretty good.
#9 _SL/R SS A9X_
Posted 23 March 2006 - 07:49 AM
Could you please get some pics up?
Im interested in the Boot Floor.
Jason
Jason
Edited by SL/R SS A9X, 23 March 2006 - 07:50 AM.
#10 _UCMEGO_
Posted 23 March 2006 - 07:15 PM
Here mate i put up some pics of the floor on my car domain page http://www.cardomain.../ride/2211769/1
as can bee seen there is a bit of severe rust on the right hand back section but othere than that all else is just surface rust and clean.
