On an LJ, Is it factory to have the 2 top mounting tabs for an LC grille? They are up behind the panels either side of the LJ grille.
LJ with LC grille mount tabs
_NURVUS_
, Apr 22 2009 12:47 AM
4 replies to this topic
#1 _NURVUS_
Posted 22 April 2009 - 12:47 AM
#2 _gtr161s_
Posted 23 April 2009 - 08:01 PM
Are you talking about the tag that is located just behind the dropper ?
If so, Im guess here, but when the lj went thru a cosmetic change with grill and headlight surrounds gmh probably didnt see the point ($$$$$) in deleting that part when the dropper would cover it
Posted 23 April 2009 - 08:40 PM
hi i have a nos nose cone for lj and it has the lugs on it
#4 _NURVUS_
Posted 23 April 2009 - 10:11 PM
Thanks guys, yeah thats them. Those LJ droppers have been rewelded in and are cracking which is when i noticed those LC lugs, and i can't read the body number. If they were'nt meant to be there i'd be concerned.
Thanks for that.
Thanks for that.
#5 _gtr161s_
Posted 25 April 2009 - 09:16 AM
Im sure these droppers were lead wiped then only thin skin of nicky was used but since most of these car have had a front ender the dropper were tack weld in then bogged up thus the cracking.
I just finished fixing the same part on an xu1...cut them off, repositioned (make sure they sit in the right position without bending to pick up screw holes), fully welded then a skin of nicky
