hey chaps
just changing my front wheel bearing as it shat itself. Question is how tight do i do up the center bolt? i was told to tighten it all the way till its nice and firm and then go back half a turn and slide pin in? is that right? or maybe tighten and then loosen 3/4?
Wheel bearing
laspy
, Mar 17 2006 12:40 PM
5 replies to this topic
Posted 17 March 2006 - 12:40 PM
Posted 17 March 2006 - 12:49 PM
New bearing?
Tighten until the movement "just" goes when rocking top and bottom of wheel.
Then tighten to next split pin hole.
RACV MAN
RACV MAN
Posted 17 March 2006 - 01:06 PM
yes just about to put new bearing in. So i tighten till theres just a touch of slack in there... enough to rock it up and down very slightly and then tighten to the next hole. Sound right?
Posted 17 March 2006 - 01:09 PM
wait i think ive got it wrong... do you mean tighten until the movement is gone and then tighten to then next split hole
Posted 17 March 2006 - 01:27 PM
Yep! "Just" gone.
With worn bearings sometimes the rocking doesn't stop no matter how tight. These bearings should be replaced. Hope this helps for later reference.
RACV MAN
RACV MAN
Posted 17 March 2006 - 01:58 PM
or all the way up until its firm and back the adjusting nut off 1 flat...and pin in the nearest hole
