Big alternators
#1 _FCCOOL_
Posted 09 May 2009 - 01:34 PM
so now i need a new alternator, big stereo, twin thermos, 4 headlights, power windows, crane hi6, holley blue etc will probably keep a good load on the alternator, i dont want anything below 70A.
i took a old internal reg bosch alternator to the auto elecs to get it upgraded but they said they could no longer buy the parts to upgrade it.
so i got a price for a new 85A bosch and its out of my price range at $390.
Ive seen some cheap 100A chrome alternators on ebay, has anyone used one?
do they last and do they make the 100 amps,?
do they have replaceable parts?
#2 _Squarepants_
Posted 09 May 2009 - 03:36 PM
Don't bother with the 100A ebay jobby.
#3 _FCCOOL_
Posted 09 May 2009 - 03:57 PM
so really the best option might be to get a bosch 85 A wich i think is made in china now too?Someone here got one not long ago, said it was crap and went back to original. There is a recent thread here about killing batteries I think it is, it's in there.
Edited by FCCOOL, 09 May 2009 - 04:00 PM.
#4 _Squarepants_
Posted 09 May 2009 - 08:26 PM
Maybe get an older Ozzy built one reco'd if you can find one???
#5 _SS Hatchback_
Posted 09 May 2009 - 09:20 PM
I should add i got the parts at trade price.
Edited by SS Hatchback, 09 May 2009 - 09:22 PM.
#6 _keith1962_
Posted 21 May 2009 - 10:38 PM
cheers Keith
Posted 21 May 2009 - 11:14 PM
#8 _keith1962_
Posted 22 May 2009 - 05:41 PM
Are you talking about the the plugs that go on the back of the alternator????
cheers Keith
Posted 23 May 2009 - 04:19 PM
Holden did a replacement kit with the battery wire and all, need sence and load wire too, but yes if I could get the connections etc would be great, require a regulator for K1 too.
#10 _bon_scott_
Posted 23 May 2009 - 06:11 PM
#11 _keith1962_
Posted 23 May 2009 - 10:37 PM
cheers Keith
#12 _keith1962_
Posted 23 May 2009 - 10:39 PM
cheers Keith 0417643342
#13 _UCV80_
Posted 24 May 2009 - 06:57 PM
i replaced it with a new Bosch Standard amp V8 alternator and its absolutly excelent. i run twin AU thermos, cd player, guages. and have had no problems
#14 _89'King_
Posted 25 May 2009 - 03:53 PM
anyone ever heard of this problem?? if so, what can i do to fix it??
#15 _keith1962_
Posted 25 May 2009 - 05:18 PM
cheers Keith
#16 _UCV80_
Posted 25 May 2009 - 06:27 PM
recently purchased a 100A alternator from ebay cause i didnt think that the standard was working (running twin thermo's, stereo and the gilmer belts) however noow i have f*** all charge in the battery, so i replaced the battery but it just drains when the car is on/moving.. its ok if im just cruising cause the battery aint doing much but when i turn the indicators on or put on the headlight the radio cuts out and the gauges show that i have no volts in the battery...
Most likely the gilmer drive you have is an under drive, (smaller crank pulley and larger then standard alternator pulley)
i had soo many issues with my old gilmer belt drive so i got rid of it which fixed the problem.
Posted 04 June 2009 - 05:52 PM
#18 _bon_scott_
Posted 04 June 2009 - 07:41 PM
^^^^^ Thats great wait it shits itself then what do you do for warrenty????????
cheers Keith
No idea, I imagine the cost of sending it off to be repaired would outweigh the cost of a new alternator. But thats what I have to do if I want a 120amp one as noone stocks them and according to a few places you can't get the bits needed to build a 120a bosch one anymore.
#19 _keith1962_
Posted 04 June 2009 - 10:37 PM
cheers Keith
P.S. all with warrenty
#20 _bon_scott_
Posted 04 June 2009 - 11:27 PM
Chris
#21
Posted 05 June 2009 - 12:27 AM
If you're interested in making it look pretty, the casing is alloy, so it can be either polished or chrome plated if you're willing to pay someone to strip it and rebuild it. If you buy one from a wreckers, get it stripped, plated then rebuilt to save some money. I used to run a 308 torana with a VN alternator, big battery, thermo fans, huge stereo and high capacity headlights and spotlights without a problem.
#22 _keith1962_
Posted 06 June 2009 - 07:08 PM
cheers Keith
#23 _bon_scott_
Posted 07 June 2009 - 10:55 PM
Chris
#24 _Roadknight_
Posted 08 June 2009 - 09:48 PM
Most of the stretch limos do because of all their interior lights.
If you have a 8 then there are two mounting positions, if u have a 6 then may have to make a new position.
#25
Posted 03 September 2012 - 11:21 PM
I have got the same problem in that my 120amp alternator(thanks Keith) will not charge the battery a idle shows11.8v with lights and fan on
Does anyone make a smaller alternator pulley for a v8 setup
