6 and V8 diffs
#1 _SAS31_
Posted 09 June 2009 - 07:46 PM
Just want to know the difference between a LH/LX 6 cylinder diff centre and a LH/LX V8 diff centre and is a LC/LJ diff centre different to a LH/LX diff centre?
Asking because I am chasing a diff centre for my LH SLR 5000.
#2 _gearex_
Posted 09 June 2009 - 07:51 PM
Edited by gearex, 09 June 2009 - 07:53 PM.
#3 _torana_umunga74_
Posted 09 June 2009 - 07:52 PM
Hi
Difference is the yoke. Early LH SLR5000 (like pre L34) should be coarse spline, L34 onwards should be fine spline.
Posted 09 June 2009 - 07:59 PM
Posted 09 June 2009 - 08:06 PM
That's the sound of the crownwheel trying to break out of the back of the housing!V8 diffs go "BANG" louder
As far as I know a lot of the LX ones were still coarse spline even in the V8s, so yeah the only difference is the yoke
#7 _SAS31_
Posted 09 June 2009 - 08:10 PM
Posted 10 June 2009 - 09:08 AM
I think the long bolt is early holden, like HR and older.
Posted 10 June 2009 - 09:55 AM
Posted 10 June 2009 - 04:27 PM
Yeh? my LX manufacturered 12-77 had fine spline 3.9 ratio its original factory 4 cyl format. I find it some what unusual the the 6 and V8 of the
time would still have had coarse while they where putting fine in super powerful 4 cyl model.
#11 _SnotGobbler_
Posted 14 September 2009 - 08:00 PM
The long and short bolts are for different ratios; 3.08 and 2.78 have the long bolts as the housing is shaped differently to give more clearance to the larger pinion
question on this.
my lj has the 2.78 diff ratio, i want to change to 3.36. will the 3.36 fit into the 2.78 housing or will i have to get a 3.36 housing, or there is a easy mod??
Posted 14 September 2009 - 08:03 PM
#13 _SnotGobbler_
Posted 14 September 2009 - 08:19 PM
The 3.36 will bolt in, you just need to use a second short bolt because the 2.78 housing will have a female thread on a second hole (besides the drain hole at the bottom), whereas the original 3.36 one would have had a stud.
thanks. sounds easy as
one more question, these banjos ok behind a warm 6 with about 200+hp? street driven, odd drag at the lights/tyre smoking. nothing too hectic like strip work. have a 9inch, but think ima have to sell to cover extra panel work *sigh*
Edited by SnotGobbler, 14 September 2009 - 08:20 PM.
Posted 14 September 2009 - 09:20 PM
It is sad but true, Holden did put coarse spline axles in the 6/8cyl cars and reserved the fine spline axles for the 3.9 centres.
I just don't know what drugs they were on at Holden sometimes.
Posted 15 September 2009 - 07:12 AM
It should be fine, if in good condition. You will always be able to destroy the Banjo if you really try, but mine held up behind the V8 until I started drag racing and abusing it in general. An open diff will generally last longer because it doesn't tend to stress the axles as much (the weakest link).one more question, these banjos ok behind a warm 6 with about 200+hp? street driven, odd drag at the lights/tyre smoking. nothing too hectic like strip work. have a 9inch, but think ima have to sell to cover extra panel work *sigh*
The 9 inch is overkill in my opinion, sound insurance but a lot of unsprung weight in a small car.
#16 _beergut_
Posted 18 September 2009 - 11:10 PM
Posted 19 September 2009 - 12:58 PM
12-77 is fairly late, I think most LXs came with fine spline axles, maybe not the very early ones.Yeh? my LX manufacturered 12-77 had fine spline 3.9 ratio its original factory 4 cyl format. I find it some what unusual the the 6 and V8 of the
