Changes to Vehicle Modification rules?
#26
_moot_
Posted 16 June 2009 - 10:06 AM
#27
_its me_
Posted 16 June 2009 - 11:07 AM
#28
_NURVUS_
Posted 16 June 2009 - 12:14 PM
Original tare mass (kg) x 0.183
max. capacity in cubic inches
Original tare mass (kg) x 3.0
max. capacity in cc�s
Therefore a car weighing 1098kg, the max is 3.3 litres under LA2.
The above figures are taken from the review doc, not the current doc. Even so, when is this NCOP going to be adopted nationally?
Big T, those are the current QLD laws for 4 cylinders cars.
#29
_Lx-Torana_
Posted 30 August 2011 - 12:15 PM
Found this group on fb: http://www.facebook....71726756173489/
but it basically links to: http://www.infrastru...1jan2011_v3.pdf
and to quote someone from the facebook group:
Cars:
- You can no longer increase your tyre rolling diameter by more than 15mm for passenger cars. So for get about fitting a nice pair of 26" street radials on the rear of your muscle cars & no more 20-22" rims for the ricers.
- Replacement engine sizes will be drastically reduced. So no more 308's in LJ toranas, no more 350's in LX toranas, no more V8's in capri's or cortinas, etc, etc. And as for forced induction, with the limits to be imposed you wont even be able to turbo or blow your original engines in most cases.
- Streetrods will become a thing of the past.
4WDs:
- You can no longer increase your tyre rolling diameter by more than 50mm on your everyday ride. So no more fitings a set of 35's to your patrol or landcruiser and if your lucky you may just be able to fit a set of 31's to your hilux navara triton or rodeo. How crazy's that.
- You will no longer be able to raise your vehicle cab more than 6" total, inclusive of that resulting from suspension lifts, body lifts and from larger tyres.
- To get a vehicle lift (like just mentioned) for more than 2" engineer certfied will set you back thousands with all the bulshit testing that will have to be done on a closed circuit test track. From what I here it will need to be done on an unused air-strip, so you will be going somewhere like goulburn or somewhere in the sticks to do it & good luck getting an engineer to travel that far away to do it for you. This shit will end up impossible to get done.
- Bye bye modified 4Wd's and the massive small business workshops and parts industries that it supports. Hello social security.
Mini-trucks:
- Well all ive got to say is do you remember VSI-50 ! Bye bye chassis notches, drop-spindle & fitting 20" wheels. Bye bye minitrucks and the massive small business workshop and parts industries that it supports. Hello social security.
#30
Posted 30 August 2011 - 12:27 PM
While VSB 14 provides advice on the construction of Individually Constructed Vehicles (ICVs) and
the execution of modifications, it is not to be taken to be a design manual. Determination of
component strength, performance, suitability and functionality must be either calculated or
determined on a case by case basis by suitably qualified personnel experienced in each matter under
consideration.
#31
_Herne_
Posted 30 August 2011 - 12:29 PM
Thought it'd be Easier just to bump this old thread rather than making a new one... not sure if this has been discussed before but from doing a search could only find this thread.
[quote]
[b]Cars:
quote no more 350's in LX toranas, end quote.
Wrong....
Herne
#32
Posted 30 August 2011 - 12:58 PM
Modifications that will need certification-
Modifying the engine and engine components that results in an increase in engine power
of more than 20% and/or affects exhaust emissions.
Well im #@$^%&....
#33
_Big T_
Posted 30 August 2011 - 01:15 PM
QLD hasnt adopted the NCOP as yet so it's still 350 LH's and 308 LJ's for us
#34
Posted 30 August 2011 - 01:22 PM
There is a fair bit of over restrictive rulings in there, but there are also some relaxed portions such as fitting other manufacturers engines to early model vehicles and not needing a engineers certificate if its not more than 20% of the maximum power in that model (works well for LH-LX guys, use the L34 output etc)
the one thing I do wonder is, are the coppers going to have a portable dyno now?
#35
_Herne_
Posted 30 August 2011 - 02:46 PM
Unfortunately the coppers dont need tools, all they need to do is have a suspicion and then send us in for a test. They dont say our car is illegal, they claim it might be and thats enough. :(Just read through the whole thing.
With regard to the NCOP and rego etc, yes us guys in Canberra all know to at least register our cars within each 12 months (even if only for 3 months)whether its off the road or not
Herne
#36
Posted 30 August 2011 - 03:11 PM
#37
Posted 30 August 2011 - 03:55 PM
But the confusion really starts if you have a pre pollution 308 with VN heads and injection with an aftermarket computer, where does that stand! lol.
#38
Posted 30 August 2011 - 04:33 PM
4WD height restrictions are already the same.��NSW already abides by pretty much that document.
And street rod regulations are totally separate, so this would have little effect.
If you get stopped and your car doesn't comply with your states regulations you're done.��And if the rules change on a Wednesday and you go cruising Friday night without adjusting to the new regulations, tough luck princess should you get pulled over.
I would have thought the coppers would make more revenue pulling every 4WD on theBruce Hwy over than targeting street machines.
In QLD we have TMR flying squads of Inspectors and the coppers hold you on the side of the road til these qualified mechanics turn up......
Grant..
